Tuner Pro Knock Sensor test/control?
Old Dec 21, 2013 | 11:01 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I am getting under my car and it looks like passenger side between 6&8 plugs the knock sensor with a 1 wire open face style plug is disconnected.
My car starts and runs and idles and timing est and not seems to be ok
It definitely sounds like misfire and lean in TP with BLM most plugs seem ok a few are rich others slightly lean could be injectors.
But I have not driven much, on the gas PT it definitely feels retarded or sounds like underwater a little.
I am changing plugs, knock counts look low 9-20 range sometimes 0-5 at idle.
TP and Datamaster look to be 31 deg at OL and 21 at CL about what is in the tables.
where do you control the knock sensor switch limit for retard in the bin?
where can i monitor spark retard in TP?
can I test my sensor in the block?
Old Dec 21, 2013 | 04:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tuner Pro Knock Sensor test/control?
That would be the coolant temperature switch for the fan. The knock sensor is down lower by the pan rail. In front of the starter. Note that they both use the same connector and it is common for the two to get swapped.
RBob.
Old Dec 21, 2013 | 04:42 PM
jjcuff1's Avatar
So there are 2 sensors nearby the upper one is disconnected the lower one is still connected
But cts seems to work up by the TB and tuner pro and ECM report no codes at all
So what problems will I see with this unplugged ?
Old Dec 21, 2013 | 05:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It isn't the CTS for the ECM. It is a switch to turn on the cooling fan once the engine coolant temperature reaches about 228* F.
RBob.
Old Dec 21, 2013 | 07:42 PM
jjcuff1's Avatar
Ok emergency thing my fan kicks on now but Motor is screeching and going to replace
The left driver side one the right one is for ac which have not used yet
So is there a reason to unhook this?
Old Dec 22, 2013 | 04:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The secondary fan temp switch is close to the exhaust. the terminal housing often wraps over time or becomes brittle and breaks. You can repin it with a delphi 13510096 black housing. Or 13510097 for grey.
http://www.mouser.com/ProductDetail/...EI%252bgV1HA==
92firebirdguy
Sep 1, 2016 07:53 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
85Special
Sep 3, 2015 04:21 PM
