MAf Tables $32B which way adjust?
Old Dec 22, 2013 | 08:54 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I have seen the tips for the MAF adjustment and tune in here but I have also seen contradictions.
If I am running lean at 140+ BLM at idle. I used the BPW tables but the MAF seem more repsonsive.
If at 10g/s is where I am lean by loking at cell 16 at idle and 800 -1200rpm range in tuner pro I got too table #1 and I find say 10.4 g/s value
OK since at 10.4 it might by .7 volts I want more fuel.
I see at 13g/s the next cell it is .9volts.
so I am thinking I make the 13g/s cell closer to 10. and the 10g/s like 9
this way when the table looks up 10g/s it will pull .9v not ,7?
am I reading this right?
So if lean, lower value in the few cells so the table shifts to a higher cell?
Old Dec 23, 2013 | 08:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: MAf Tables $32B which way adjust?
It is the opposite, the MAF voltage is used to look up and fetch the gms/sec value.
RBob.
Old Dec 23, 2013 | 08:58 AM
jjcuff1's Avatar
ok that makes more sense
So as an example the maf table#1 in the conversion x *(y/256). This conversion is for the actual input from the ecm address to be converetd to the voltage. which then is looked up against the table row.
so the ECM will read at the address perform the calc. So y is the byte/256 = volts (what is the x?) but I assume it then determines it is say .55v
then it goes to that row and returns say 10g/s
so if I am lean at 10 g/s I should LOWER that value to say 9g/s so it goes to the next row/cell
Old Dec 23, 2013 | 12:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This should help:
https://www.thirdgen.org/forums/diy-...scellanea.html
RBob.
BumpaD82
Feb 26, 2016 02:57 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
