ebl surging idle thread
Old Oct 11, 2014 | 09:27 AM
  #51
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ebl surging idle thread
Originally Posted by TORN
Also my SA - idle state SA is at 20 but its jumping from 21 to 13 and never stops.
The idle compensation SA is what causes the SA to change. You can zero the two SA tables to prevent it from changing:
SA - Idle Low Compensation
SA - Idle High Compensation
Surging is typically caused by a lean area of the VE table.
RBob.
Old Oct 11, 2014 | 09:46 AM
  #52
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Thank you. I hope timing sets still so I can get the VE correct. I see it going lean after it starts the roll but its tough to pull a VE learn at that time.
Old Oct 11, 2014 | 10:48 AM
  #53
TORN's Avatar
Car: 88 IROC-Z
Well it wasn't the timing. its dead steady now. I am about to start over and get another set of injectors to see if I can get control of these things. I am running Bosch III 24# that were opened up to 42#. Rob has hated the idea of these since day one so I am getting injectors I can set up right. Am I on the big side for a 421 @ 42# stock pressure?
Old Oct 12, 2014 | 09:45 AM
  #54
RBob's Avatar
Car: check
Engine: check
Transmission: check
Eight 42 #/hr injectors will support 635 HP at .45 BSFC and 85% DC.
RBob.
Old Oct 13, 2014 | 09:26 AM
  #55
Ronny's Avatar
As you are prob aware you are leaving idle SA (0 tps%) and ECU is looking at SA tables at that point. I would try change that area where commanded SA is under 13 to 21-22 and ramp up from there.
I suspect lean condition off idle. If you have a WB you could verify that. I would add more IAC fueling post idle.
Old Oct 17, 2014 | 10:28 AM
  #56
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Originally Posted by RBob
A lot of the ideas that are being kicked around I covered in my first port (#3 of thread). It would be helpful to reread that post.
As far a tuning in the proportional gains tables, I go by exhaust sound and the INT. But first, I rough them in by changing them by the same amount of change in injector flow rate. If a larger displacement engine is in place, say a 383, that too needs to be taken into account.
It is all about ratios. Double the injector flow and need to halve one of the two proportional gains tables. The two tables get multiplied together, hence the need to only halve one of them.
If at a steady state cruising speed the exhaust sounds like there is a bad u-joint, too much proportional gain. Look at a data log and look at the airflow at that time (gms/sec). Go into the proportional gain vs airflow table and reduce it at and around that air flow.
Flash and re-test.
As for using the INT, if the INT is rapidly increasing and decreasing there is too much gain. Would likely see this in the bad u-joint example.
A slowly increasing and decreasing INT means that there isn't enough gain. This forces the ECM to use the INT to create cross counts (O2 signal). This causes an overshoot of the AFR. Which can be heard in the exhaust an oscillation. Can also cause the engine RPM to follow the AFR change.
RBob.
RBob,
Odd though that after you looked at my logs, I began to increase the prop gains from
where I had them. They're just about back to stock. And that was to tame the INT being used for x-counts. As an example, I went from 2 count at 0gms to 9.
I did note a bit of a "heavy breathing" at idle if I went further. A bit of an up and down, but motor is cammed and idle varied 875-930rpm. At cruise, motor is monotone. Just a consistent engine note and the INT/BLMs are much steadier. This also allowed me to tune the IAT COMPENSATION so the BLMS remain steady even as IAT temps change.
Old Oct 17, 2014 | 10:43 AM
  #57
TORN's Avatar
Car: 88 IROC-Z
Switching to 42# bosch greens fixed my surging problems.
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
jbd1969
Aug 17, 2015 07:06 PM
