zero out adder tables
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I need to know exactly how to zero out ALL SA adder tables .. I only want to use the main and extended SA tables for my timing .. thanks in advance ...
Car: check
Engine: check
Transmission: check
Re: zero out adder tables
Not all of the SA tables are adders. Many can both add or/and subtract. But to run on only the two main SA tables...
EBL Flash, here is what to do:
That should cover it. May have missed something, just double check it.
RBob.
Code:
Zero out: SA - Idle State SA SA - IAT/CTS Comp Bias SA SA - Coolant Comp Bias SA SA - ALDL Mode Added SA - PE Attack Rate/Fifth Sec SA - Coolant Comp Spark Advance SA - IAT/CTS Compensation SA - PE Adder vs Gear/RPM SA - TCC Locked Retard SA - Idle High Compensation SA - Idle Low Compensation SA - HiWy vs MAP SA - Launch Mode SA - Startup Choke SA - Attack Rate Un-check this option flag: Option Word 2 - Bit 1 - IdlSa
RBob.
Car: check
Engine: check
Transmission: check
Try it and see? I was wondering why you would want to do this. I did it once but only to test the latency of various ICMs. Although I did start the engine on a normal calibration then switched t the one with the set values.
RBob.
RBob.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
My thoughts as well. Some adder tables address specific situations that are transitional.
Car: 92 camaro
Engine: 406
Can you send me a picture of how you zeroed out tables on you pe table for example I just learning what these terms are
86CamaroDan
Sep 29, 2015 10:08 PM
sailtexas186548
Aug 24, 2015 10:11 PM
