Tune Tranny AE/TCC with TP?
Old Mar 16, 2014 | 02:26 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Getting closer to driving the IROC. 88 auto 305 tpi stock
I have been tuning with TP and working well but my speedo and tach were broken. So I think much of my tune was only at idle/park once I drove with no speedo feedback it was very lean
now it starts up idles fine runs well at idle and low RPM like 128-130 BLM at higher TP and LV8 i get some retard and runs in the 131 but still better then 134 from past
I will lower the fuel constant slightly to get fuel across the board. But the car feel liek it is not shifting into gears under load at right time. lockup?
SO I suspect since I am TP in the 1-4volt range I am hitting AE/PE ranges so that can explain the lean condition as well since I did not touch those yet just MAF tables and idle.
I will play with AE/PE I can see that result with TP pretty easy but what am I looking for with the tranny? I see TCC but what should I be looking for in TP or what should I be feeling when I drive?
And for AE/PE what are simple tips to tune 1 then the other. effectively lock out in TP? I am using $6E
Old Mar 16, 2014 | 03:06 PM
jjcuff1's Avatar
Re: Tune Tranny AE/TCC with TP?
Just looking for quick tips on best way to dial in AE/PE and how to test for TCC tune with TP. Is there a way to monitor TP vs Speed or RPM to look for shift etc
Old Mar 16, 2014 | 06:33 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Is it just that your speedo doesn't work, or is the ECM also not getting a VSS signal?
Old Mar 16, 2014 | 10:08 PM
jjcuff1's Avatar
My speedo cable was broken once I fixed it the ECM sees the speed
And that is when the Blm and car felt a little better too.
But trying to figure out best way to tune in ae pe with te tcc if possible in tuner pro
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
