Running EBL for engine, and 16147060 for trans
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
I may be getting my old 1993 K2500 Suburban back. Has a 5.7 w/4l80e. My brother has had the truck for a few years now, and has since changed the engine out for some hotter, (no tune, long story).
Since I have ran the EBL classic for ever on my old wagon, and now have the SFI-6, I would love to run it on the burb.
Has anyone done this yet? what inputs would be need for the 7060 to keep control of the trans?
Can I just splice from the DRAC to get the VSS to the EBL?
I have a tone of questions, I also have a ton of spare parts, harnesses, ect.
Thanks guys!!!
Thanks guys!!!
Car: check
Engine: check
Transmission: check
Re: Running EBL for engine, and 16147060 for trans
This has been done quite a few times. Grumpy (rip) was the first to do it on a BBC truck with the 4L80E. Pin C1 or C11 on the DRAC provides the 2K PPM VSS for the EBL ECM. IF you want a knock system need to add an external knock filter.
Other then that, add the two connector shells, move the engine control terminals/wires to those connectors, splice in IGN+, battery and ground along with a few shared sensors.
Shoot me an email for the re-pin guide.
RBob.
RBob.
Transmission: 2004R
Will do, I was reading some old posts, thank you!
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
