How to get AE vs RPM on 7730
Old Jun 27, 2014 | 11:35 PM
ULTM8Z's Avatar
So I found a trick...
Enable the setting "Reset Integrator when AE in progress"
Then, play around with the VE at high MAP
It's working out big time for me. Instead of global delta MAP or delta TPS changes ( sometimes resulting in areas where i dont want it( I can target AE directly to the RPM range I want.
I think what's happening is the ECM is momentarily disabling the auto-adjust when there's a change in throttle position, so while it's "looking the other way", I sneak in some extra fuel via the VE table without the ECM trying to trim it back out. By the time the AE event is over, it's too late for the ECM to do anything about it.
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Damon
Sep 26, 2015 04:29 PM
BWilcox
Sep 20, 2015 12:19 PM
