Diving into tuning, started with MAF tables. Need low RPM stutter advice
Old Jul 6, 2014 | 03:32 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Hey everyone,
Got my engine back together and started tuning. I have been reading alot in the MAF section of the sticky and adjusting MAF tables for optimal BLM. No matter what I do, I am getting a nasty low rpm stutter and i have a feeling it has something to do with something else. Car is also idling extremely rough (due to cam?)
08-502-08 compcam
Vortec heads
FIRST tpi intake
new southbay 22lbs injectors
Hooker shorties
All attached to a stock L98 bottom end
I started tuning the APYN3496 that my car came with originally. Should I switch to ARAP?
Also noticed that INT is bouncing back and forth when held at a steady TPS voltage. Does this indicate some type of vacuum leak?
I attached a short low RPM log, the car stutters quite a bit in this area.
File Type: txt
jklein337
Sep 19, 2018 06:23 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
