0411
Old Jul 21, 2014 | 02:07 PM
kenjames23's Avatar
Car: 1982 Z28
Engine: 350 880 block
Hello i have been reading about this 0411 pcm swap and i am very interested about doing this i know i am very late on this but i just got me a 1982 z28.What i would like to know is what do i really need for this swap do i go to the junk yard i do i buy the stuff from EFI Connection. thanks for any help you can give me
Old Jul 21, 2014 | 02:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 0411
Gotta find a pcm and buy the cam sensor and crank sensor, crank 24x ring, timing cover, and or cam sensor distributor housing for it to work.
Efi connection has the old cam sensor distributor for lsx coils or they sell the billet cover that places cam sensor on the nose of cam. No longer using distributor side.
Need ls1 harness from some lsx vehicle.
You will have to cut and rewire to fit engine bay and to integrate it to the stock gauges or whatever gauges you desire. Its an involved project but not super complicated as long as you can read and understand wiring diagrams
Old Jul 21, 2014 | 06:00 PM
kenjames23's Avatar
Car: 1982 Z28
Re: 0411
thank you for your reply should i just buy everything from the junk yard or is their some where else i should buy it
Old Jul 21, 2014 | 09:34 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Re: 0411
I think the simplest way with an SBC to go 0411 with CNP is to get a new vortec timing cover (~$22.00), use a vortec distributor for the cam sensor and to drive your oil pump, and get the small diameter 24x ring from efi connection.
You'll have to use a timing gear/balancer combo that works with the slight thickness of the sensor ring (same as a vortec).
Old Jul 22, 2014 | 06:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 0411
Yes thats likely best way but gotta be careful with the vortec cover on older blocks. It doesnt seal well and requires some rtv work in certain areas.
Also there are very few balancers that work with vortec cover/crank sensor combo. Ati super dampers do that have the thin 1.2-1.3" thick shell. Most others are over 1.6"-1.7" and are to thick. They hit the sensor before goin on
88FormulaKiller
LSX and LTX Parts
30
Jan 10, 2019 08:41 PM
Fast355
Dec 2, 2016 06:33 PM
etizz
Nov 12, 2014 05:21 PM
dhirocz
Dec 20, 2011 04:22 PM
