EBL tuned for Manual
Old Aug 28, 2014 | 04:30 PM
slrvette's Avatar
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
Been a while since I've posted. I have EBL/Flash running a 388 with HSR. The car is an Automatic has been fully tuned with pretty awesome numbers.
I've been thinking about going to a stick (manual), I was wondering if I do is it just a matter of unchecking for checking the correct flag or will I need to jump on a dyno again to get a full tune?
Old Aug 29, 2014 | 08:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL tuned for Manual
Un-check the TCC option flag, can set the N/V option flag which will allow for different PE SA for each gear. Also need to fill in the N/V ratio versus gear table.
Off the line will need to be tuned, plus the IAC stuff for crank to run may need to be changed some. This has to do with the difference in loading on the engine between the two types of transmissions.
As for WOT, the lower RPM stuff, up to say 2200 RPM may need some changes. This is due to a slipping torque converter versus a solid lockup of a clutch.
RBob.
Bubbajones_ya
Jul 6, 2024 08:32 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Magman
Sep 12, 2015 11:55 PM
85Special
Sep 3, 2015 04:21 PM
