BP Microsystems EP-1 Software
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Does anyone happen to have a copy of the EP.exe dos software file for the old BP Microsystems EP-1 Eprom writer?
I have had this system for years and somehow have lost my disc.
Now I am up the creek.
Transmission: 5-speed/T-5
Re: BP Microsystems EP-1 Software
You might be better off buying a new programmer, such as the Moates BURN2, if you are only doing automotive EEPROMs, such as the 27SF512, or a WIllems (I have a GQ-3X) if you are using a wider selection of E/EPROMs. Both can be purchased for around the $80 mark. There are a few cheaper Willems programmser, but they usually require a parallel port.
I did a quick search on the programmer you have and it seems to be very old, with some software that was done in DOS, and people didn't seem to have much luck replacing their software, when they were in a similar situation as you are.
Car: 1986 IROC Z-28
I have the original huge floppy disks lol, and back when I used this before I just moved the data from those to a 3 1/2 floppy. That's the one I can't find.
