I have the flash ebl and was curious about what I could modify that would definitely increase performance in my ride. It's a 5.0 6spd and I've gotten it to run really welk at this point by running learn ve sessions. I have a stable base, but now I want to start doing more. Any recommendations on where to start? I'd like to modify the bins myself rather than just using one someone throws together for me.
Fast355
close
- Join DateJan 2005
- LocationHurst, Texas
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car1983 G20 Chevy
- Engine305 TPI
- Transmission4L60
- Axle/Gears14 bolt with 3.07 gears
- Liked:508 Times in 436 Posts
Quote:
I would suggest a wideband and targeting somewhere between 12.2 and 13.2 air/fuel ratio depending on the ethanol content of the fuel in use. Then dial in the timing advance curve. The car will most likely enjoy a much more rapid advance curve and perhaps a smidge more total advance. Check your distributor module as well. If it is a factory module make sure that it is not an 048 module but rather a 369 module.Originally Posted by Es_91rs
