EBL start up calibration suggestions please
Old May 30, 2015 | 10:25 AM
pfreer3's Avatar
Had a catastrophic engine failure and had to start over...
I'm needing any suggestions as to which EBL P4 calibration to start from, and what to adjust as a baseline. I was planning to start from the EBL_P4_3000 calibration bin, but what else???
Here's the setup
EBL P4 - TPI
L31 gmpp crate engine (vortec heads / roller cam)
Lt4 hot cam
1.6 roller rocker
Scroggins Dickey Vortec TPI intake manifold
Large tube runners / stock plenum / stock TB (for now)
36lbs./hr injectors
Thanks in advance for any information
Old May 30, 2015 | 07:10 PM
CORV3TT3's Avatar
Re: EBL start up calibration suggestions please
Here's the setup
EBL P4 - TPI
Lt4 hot cam
1.6 roller rocker
36lbs./hr injectors
The SA table should be the one that is for the heads. So, yeah... you have Vortec heads so go with the 3000 file.
If it were me... I'd migrate where max VE sits for a TPI motor up about 500-1000 RPM to get started. Basically, shift the whole table up.
At least that's where I started for my motor.
A WB sensor is really helpful for setting and resetting VE tables with EBL since it can learn PE mode. It's a GREAT investment and in my book- a must have.
Old May 31, 2015 | 07:16 AM
pfreer3's Avatar
Oh yeah forgot to mention ive got a TT1 wb as well...
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beast94
Aug 20, 2015 06:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
drathaar907
Aug 6, 2015 04:20 PM
