High BLMs but high HC ... failed emissions
Old Jun 2, 2015 | 06:23 PM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
at 2500, my HC is 111. Max on the test is 200.
But at idle which is 750, the HC is 1300! Max is 200.
My BLM at idle is 131, at 2500 its 134.
How could this be?
Could the cat be bad? Could there be an oil leak somewhere - though I dont know if that would affect idle HC since the O2 sensor would pick it up and show it.
Huh??
Old Jun 3, 2015 | 07:38 AM
ULTM8Z's Avatar
Re: High BLMs but high HC ... failed emissions
Huh??
Not necessarily... Keep in mind the ECM only monitors the side of the engine with the O2 sensor. You could have a malfunction on the other side and the ECM will think everything is dandy.
I think the O2 is on the driver side on thirdgens? In which case, I'd check the ignition components on the passenger side.
Old Jun 3, 2015 | 08:48 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
May want to consider your cam overlap and read up on O2 window settings.
Old Jun 8, 2015 | 10:26 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Not sure what Cam you have...
May Consider this..
https://www.thirdgen.org/forums/diy-...ome-those.html
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
