EBL in open loop-VE learn- check my logic please
Old Jun 3, 2015 | 05:47 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Ok I'm running open loop with EBL so there's no ecm O2 sensor based adjustment.
In the morning when it's cooler and engine temps are on the lower end (say 89-92C) a wide band based VE learn wants to pull fuel- engine running rich.
With the same tune (not the velearned tune) in the afternoon when warmer (CT 95-100) the ve learn wants to add fuel, engine running lean.
I'm thinking that my IAT/CT blend table is too far toward the IAT, % low. I believe I need to raise the value to be more bias toward the coolant temp so less adjustment is being made. ??
Now the last part is the slope. How do I know or is it just going to take a point by point at different temps/loads/gmsec? Currently I have a fairly flat slope, 60 @ 0, 25 @ 255. Should I raise the whole table or just the gmsec encountered when cruising?
Any thoughts will help. This has been one area of challenge for me.
Old Jun 3, 2015 | 08:20 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
I've always set up my Wide Band VE learns to only make corrections when the motor is fully warmed up. Then adjust the cts vs. afr table to get all other cts temps in line.
Old Jun 4, 2015 | 05:42 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Re: EBL in open loop-VE learn- check my logic please
I agree, what I'm trying to do is get the blend table set. The motor is "fully" warmed up but there's a slight difference in coolant temps and mostly ambient temps from morning to afternoon. The engine/cooling system has reached an equilibrium for the conditions. The difference in VE learns is an indicator of what's going on.
To be exact on the temps, during cruise the CT/IAT=blended values are...
Morning 90/18=49
Evening 95/29=58
So about a 10-11 degree temp difference in the blended value. Is this enough to make a fueling change?
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
tcflint
Sep 14, 2015 04:55 AM
1992Vortec
Aug 31, 2015 08:05 PM
soarestransam
Aug 24, 2015 08:15 AM
beast94
Aug 20, 2015 06:44 AM
