Help! EBL P4 flash boosting noob
Old Oct 27, 2015 | 01:23 PM
LegacyThirdGen's Avatar
Car: 1987 IROC-Z
Engine: 355TPI
Transmission: TCI SF 700r4
Axle/Gears: Borg-Warner 3.27
So I'm still trying to learn how to tune my car. So far it's been rather fun, but so much information to take in.
So I come to the best place for help. My brothers.
I seem to be having a problem when I'm out of boost. The car feels like it's spitting and sputtering from 2000-3000rpm and 50-80kpa on the map sensor.
Car is an 87 with a 355 tpi and an ebl p4 with 24lb/hr injectors. Trying for 6psi on an eBay turbo.
Attached is my bin.
File Type: bin
Old Oct 27, 2015 | 07:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Help! EBL P4 flash boosting noob
Did you do any VE Learns? Grab a data log and pore over it, with that can mostly see what is going on. How far off are the BLM values once in closed loop? Any knock taking place?
RBob.
Old Oct 27, 2015 | 08:54 PM
Car: 1987 IROC-Z
Engine: 355TPI
RBob.
Did a few VE learns and was still iffy. Gonna get back to you with the data log.
Old Oct 28, 2015 | 01:18 PM
Car: 1987 IROC-Z
Engine: 355TPI
Got the data log, drive to work today was wetter than usual. Had to stop by the bank before heading in about half way through.
Silly Billy website not allowing .dat files.
File Type: rar
Old Oct 29, 2015 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The fuel trims are very low, was the injector flow rate and engine displacement parameters set? If not set those first. Then run VE Learns, if you feel comfortable doing it can also manually lower the VE table.
Stay out of boost and get the VE squared away first.
RBob.
Bubbajones_ya
Jul 6, 2024 08:32 PM
91 zeee
Oct 26, 2015 12:14 PM
Quzyle
Oct 15, 2015 03:35 PM
91 zeee
Oct 13, 2015 06:51 PM
