VSS options
Old Nov 3, 2015 | 10:49 AM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
VSS options
It has been a long time since I have posted a thread on Thirdgen, but am a daily viewer. I have been tuning for a few years now and have learned a lot from this forum, and have a pretty decent tune going for my car.
I have looked long and hard for a solution to my idle problem on my t56 swapped IROC, and I was hoping there was a solution. I am working with the stock 165 ecm, in the 6e mask. The problem I am having is the car is very temperamental when shifting out of gear. It idles fine when at a stop, but when driving around it will almost always die when I take it out of gear are put the clutch in. I can keep it going by giving it a little gas, and then it will finally idle, but it is making driving a pain.
From my reading it looks like it is a VSS issue (I don't have a speedo, or VSS hooked up). Is there a way to tune this out?
Old Nov 3, 2015 | 12:08 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VSS options
Probably easier to use a Dakota Digital SGI-5 box to buffer the T56's VSS and feed it to the ECM.
RBob.
Old Nov 3, 2015 | 02:24 PM
irocman7's Avatar
Engine: Forged 383
Re: VSS options
Is there a way to tune this out of the ECM to keep it from dying temporary bandaide? I am planning on upgrading my gauge cluster, going to an electric speed and going to the 730ecm down the road.
1988_f-bird
Nov 13, 2015 06:48 PM
Jonesie1978
Nov 10, 2015 10:12 AM
S_Johnson
Carburetors
Nov 4, 2015 06:48 AM
Johny2234
Oct 31, 2015 11:27 AM
rode1951
Oct 30, 2015 02:52 AM
