Injector BPW
Old Apr 8, 2016 | 12:16 PM
htrdbmr's Avatar
Car: BMW 735
Engine: 383 W/ SUPERAM
Axle/Gears: 3.64
Injector BPW
What would be considered the highest usable BPW for a Bosch 3 injector? In PE mode high rpm/kpa, I'm seeing mid 9's.
Old Apr 9, 2016 | 10:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Injector BPW
It is easier to go by injector duty cycle (DC%). At 6,000 RPM the injectors fire every 10 msec. So a mid 9's PW puts the DC% around 95. Which is typically too high.
RBob.
Old Apr 9, 2016 | 12:45 PM
htrdbmr's Avatar
Car: BMW 735
Axle/Gears: 3.64
Re: Injector BPW
RBob.
Thanks, good to have confirmation from one of the pros
Old Jul 5, 2016 | 10:17 PM
Skye1500CHEVY89's Avatar
Car: 89 Chevrolet c1500 Cheyenne fleetsi
Engine: 383 stroker l31 880 vortec tbi
Re: Injector BPW
I would have made my own thread if i knew how on this site. Hi I'm trying to find out how to calculate bpw/bpc? For 89 c1500, I know I need 43 psi at the injectors for 400fwhp. I have a holley 670 cfm tbi unit 65lbs/hr mini delphi injectors. I have the 255 lph wal bro fuel pump, derect fit.
And an after market spring installed in the regulator. Yes I can get above 43psi. Permanent gauge install. I am using my 7747 ecu $42 mask with a 350 ci bin file. I can datalog and my ostrich 2 is on its way and will be tampering with it in the next few days. Yea I modded the ecu for eeprom chips. I have a 376.99(377) stroker... 350 with 400 crank and 3.75 rods. The none bored 383 sbc. This is my first build. Second vehicle. Geo storm gsi 92 maaaan that was I fun little car. Went to a yard.. /: now I'm on my truck and I really would love to have this on the road. Tunerpro rt 5, 5.9 xdf and 5.2 adx. How do I know if the bpw and or constant is correct??
Old Jul 6, 2016 | 07:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Injector BPW
The equation with an example:
; Val = 1461.5 * (VOL/RATE)
; VOL = Vol of 1 Cylinder in liters, (0.7125l)
; RATE = Injector flow in gms/sec
; 5.7l = 7.71 gms/sec (61.2#/HR)
Note that there is a single BPC value for when the EGR is inactive, and a 3D table of values for when the EGR is active.
RBob.
P.S. to start a new thread, on the upper left is a button just above the list of threads in that particular forum.
Old Jul 8, 2016 | 01:27 AM
Re: Injector BPW
Thanks for both (:
Old Jul 8, 2016 | 06:41 AM
Re: Injector BPW
Forgive me but I have another questions..
In the 7747 what does what? Base pulse width = ?
Injector bias? What are the differences between BPW and BPC?
ULTM8Z
95
Oct 9, 2017 01:31 PM
david068513
May 11, 2016 05:41 AM
MarkF
Apr 6, 2016 11:08 PM
Piston454
Apr 6, 2016 01:06 PM
Calixbwsx
Apr 5, 2016 03:15 PM
