Tuner pro
Old Nov 21, 2016 | 11:59 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
Tuner pro
Hi, I have a new laptop and I'm attempting to download tuner pro (no RT) but after downloading Tuner Pro V5 I don't see the Acquisition tab. I believe this is where the data stream file (adx or ads) is saved into, correct? Is it because Tuner Pro does not offer this feature and I have to download the RT version? At this time I am not interested in tuning but data logging only for diagnostic purposes. Also, the only files I see in the Tuner pro web site are Super_8dm2.ecu (bin definition) and 1227730_8D.ads (data stream). Do I have to get another file for data logging? Thanks
1990 TPS 350 stock
Old Nov 22, 2016 | 01:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tuner pro
Convert the ads to a adx or download the adx .
http://www.gearhead-efi.com/Fuel-Inj...Information-8D
Old Nov 22, 2016 | 08:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tuner pro
You need the RT version of TunerPro to data log the ALDL stream.
RBob.
Old Nov 22, 2016 | 04:47 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Re: Tuner pro
RBob.
Ok. But, is that a recent change? As I said before I had Tuner Pro in my old laptop and I was able to datasteam. Just to clarify, when I say datastream I mean able to see MAP, BLM, and all that.
Old Nov 22, 2016 | 04:53 PM
Engine: Lb9
Transmission: M20
Re: Tuner pro
Current Version: 5.00.8853 - Download (3.51 MB)
Release Date: 11/26/15
http://tunerpro.net/downloadApp.htm
Tuner pro real time is the latest to data log.
Old Nov 23, 2016 | 09:41 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Re: Tuner pro
Hi again,
I don't want to datalog, I want to datastream, be able to see dash (or list) reading.
Old Nov 23, 2016 | 10:36 PM
Engine: Lb9
Transmission: M20
Re: Tuner pro
Originally Posted by wruiz
Hi again,
Than don't hit the record button lol
Old Jan 9, 2018 | 02:53 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Re: Tuner pro
Hi,
Been a long time. I installed a HSR and I was wondering whether I need to re-tune the chip or not. Also, I'm planning on replacing the cam and heads, so, if a re-tune is needed, should I wait until the can and heads are replaced? Thanks.
Old Jan 9, 2018 | 03:15 PM
ULTM8Z's Avatar
Re: Tuner pro
You could probably see some benefits of a retune with the HSR. It'll flow sufficiently more than the TPI above 4500, but my guess is though you'll run out of cam shortly after that.
What does your Tunerpro data say in terms of your BLMs?
Old Jan 21, 2018 | 07:57 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: Tuner pro
1. Download Tunerpro RT, and pay Mark Mansur what you owe him for his time and effort. If you are serious about doing this, get the best version and pay the man.
2. You have a speed density car. Of course you need a re-tune after an intake swap like that. It will run ok I’m sure, but you will be leaving power on the table.
