Big vs Small cap distributor and timing
Old Mar 6, 2017 | 03:38 PM
devilfish's Avatar
My corvette use a big cap HEI dis:
So the distance between the "pins" inside the cap should be greater vs a small cap dis with external coil?
Is this reflected in the bin file ?
My 1991 corvette has crazy amount of part time / crusing spark advance, around 46.
On a camaro same year, same TPI but with a small cap dis with external coil, the timing is not even close that at the same MAP/RPM.
Is that why, or am I thinking totally wrong here..
Cheers
Old Mar 6, 2017 | 03:41 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Big vs Small cap distributor and timing
Aluminum heads vs iron heads is why.
Old Mar 6, 2017 | 03:48 PM
devilfish's Avatar
Hmm, there you go. Dident know that the same year Camaro hade iron heads..
Makes sense.
Thanks for explaning
//Anders
