O2 swing point in $6E
Old Apr 22, 2017 | 05:48 PM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
How do I adjust the o2 swing points in $6E using Tunerpro RT?
what tables, scalars, etc?
Old Apr 22, 2017 | 10:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: O2 swing point in $6E
tables contain adjustments for a complete range, maf tables , sa etc.
Scaler is a constant.
Old Apr 22, 2017 | 10:43 PM
Engine: Lb9
Transmission: M20
The o2 uses 500mv as a centerline above is rich lower is lean. Each swing is a cross count. Not sure what you mean bye adjusting what the o2 swing point is. Are you referring to target fuel ratio other than Stoichiometric ?
Old Apr 23, 2017 | 08:22 AM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
my hc's are high cant pass emissions at idle.
hc's normal at 2000rpm. so i think it's my aftermarket cam's overlap.
i've read if you tighten the swing point limits you can get tighter control and lower hc.
Old Apr 23, 2017 | 08:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
These, I didn't see any adjustments for idle:
Code:
    	; UPPER ZERO ERROR REF FOR SLOW o2 R/L
    	; ARAP
    	;  02-20-1997  Dissassemby of ARAP  Lines= 9
    	;  TBL =  .226  * mvdc
        ORG  $C459  ;    mvdc         Air Flow g/sec
LC459   FCB  140    ;       619            0
LC45A   FCB  148    ;       655            8
LC45B   FCB  152    ;       673           16
LC45C   FCB  152    ;       673           24
LC45D   FCB  148    ;       655           32
LC45E   FCB  144    ;       637           40
LC45F   FCB  132    ;       584           48
LC460   FCB  128    ;       566           56
LC461   FCB  125    ;       553           64
    	; LOWER ZERO ERROR REF FOR SLOW o2 R/L
    	;  TBL =  .226  * mvdc
        ORG  $C462  ;    mvdc            Air Flow
LC462   FCB  120    ;       531            0
LC463   FCB  128    ;       566            8
LC464   FCB  132    ;       584           16
LC465   FCB  132    ;       584           24
LC466   FCB  128    ;       566           32
LC467   FCB  124    ;       549           40
LC468   FCB  112    ;       496           48
LC469   FCB  109    ;       482           56
LC46A   FCB  106    ;       469           64
    	;  Fast o2 Rich/lean Treshold vs Air Flow
		;  	FAST o2 RICH IF LC4AD + LC453
		;  	FAST o2 LEAN IF LC4AD - LC453
		;	 (SUB OFF LC454 IF AIR DIVERT)
    	;  TBL =  .226  * mvdc
        ORG  $C46B  ;    mvdc          Air Flow g/sec
LC46B   FCB  130    ;       575            0
LC46C   FCB  138    ;       611            8
LC46D   FCB  142    ;       628           16
LC46E   FCB  142    ;       628           24
LC46F   FCB  138    ;       611           32
LC470   FCB  134    ;       593           40
LC471   FCB  122    ;       540           48
LC472   FCB  120    ;       531           56
LC473   FCB  118    ;       522           64
RBob.
Old Apr 23, 2017 | 01:47 PM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
Tunerpro's ARAP bin has the table "Closed Loop Rich/Lean Threshold vs. Airflow" at 0x46B, so I'm guessing the disassembly table "Fast o2 Rich/lean Treshold vs Air Flow" is the same.
Notice that there are two values for 628
This is the only table that shows up for ARAP in Tunerpro that corresponds to the three tables in RBob's post, but I may be wrong about that.
Nevertheless, should I start tightening the values in this table to shorten the swing?
