Reading Kpa's with AutoXray?
Old Dec 31, 2001 | 02:18 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Title-Is it possible? I have an AutoXray XP240 and wonder if it will display MAP Kpa's.
Old Dec 31, 2001 | 03:03 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Mine will only show the map voltage, I wanted to use Tim's method of tuning part throttle, but i dont have diacom.
Old Dec 31, 2001 | 04:00 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
It might be possible. The SnapOn scanner we have at work allows for switching between metric and standard readings so I would think something like Auto Xray would. If not I posted to this board a more or less conversion list of kpa to MAP volt readinds. Craig Moates took a look at it and saw some sort of equation that seemed to be used. Could be useful if you don't find what you need.
Old Dec 31, 2001 | 06:09 PM
Engine: 4.0L
I asked becaused the manual said the MAP will be displayed in Volts or Kpa. It didn't say how to change between the two. Might be part of the setup but I have to select 90-92 GM vin 8 right? I'm running a 730 ECM (speed denisty).
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
