Stalls after removing/re-inserting chip
Old Jun 30, 2017 | 02:47 PM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
Hello. 87 tpi with 165 ecm. Was checking to make sure my ecm was indeed a 165 to get correct definition stream. Removed memcal out of curiosity. Put back in. Now engine stalls after 2 or 3 seconds. I did attempt to datalog last night for the first time ever. For what it's worth. Please help with any ideas!
Old Jun 30, 2017 | 03:07 PM
Car: 1987 IROC Z28
Re: Stalls after removing/re-inserting chip
When I turn the ignition on the fans turn on almost as if I am entering aldl mode. I can't tell if I caused this problem by messing with the memcal or by data logging last night
Old Jun 30, 2017 | 03:11 PM
ULTM8Z's Avatar
At this point, recommend visual inspection of the memcal and socket looking for damage and/or bent pins. Then unplug the ECM, re connect it and try again.
Is this a factory memcal? No chip adapters or anything?
Old Jun 30, 2017 | 03:18 PM
Car: 1987 IROC Z28
Everything looks in order. This is I believe an ADS superchip. No adapters.
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Esd maybe
Old Jun 30, 2017 | 03:20 PM
Car: 1987 IROC Z28
Esd maybe
what's that..
I can get it to run but it idles very high. Keep in mind before last night's failed datalogging session, everything ran beautifully. I just wanted to datalog.
Old Jun 30, 2017 | 03:26 PM
Car: 1987 IROC Z28
Are you saying my bin was erased from 30 or so seconds of exposure to the sun?
Old Jun 30, 2017 | 05:38 PM
Car: 1987 IROC Z28
Esd maybe
or i fried my chip? Or ecm?
Old Jun 30, 2017 | 06:07 PM
NoEmissions84TA's Avatar
ESD - Electro Static Discharge. You might have fried the chip just by handling it.
Old Jun 30, 2017 | 06:20 PM
ULTM8Z's Avatar
If you have the factory chip, maybe put that in and see how it runs. If it runs good, then it's a problem with the ADS chip.
Old Jun 30, 2017 | 07:58 PM
GeneralDisorder's Avatar
That is the typical symptoms of a PROM error. It's trying to run on the limp mode resistor network. Fan always on and hard starting/stalling is symptoms that the ECM wasn't able to read the chip.
GD
Old Jun 30, 2017 | 08:09 PM
Did you re-install the chip correctly, (did not rotate it 180 degrees) or bend a pin over?
Old Jun 30, 2017 | 08:25 PM
Car: 1987 IROC Z28
I'm looking for it... it's somewhere around here
Old Jun 30, 2017 | 08:27 PM
Car: 1987 IROC Z28
GD
ok cool. Getting an emulator this week anyhow. screw these chips.
Going to check wiring and grounds tomorrow for now.
Old Jun 30, 2017 | 08:28 PM
Car: 1987 IROC Z28
Yes I was careful with it when I installed it and everything looks in order. I may have removed it incorrectly because I know I used a screwdriver so perhaps I did fry the chip
Old Jun 30, 2017 | 08:39 PM
ULTM8Z's Avatar
Did you remove it without turning off the ignition?
Old Jun 30, 2017 | 08:49 PM
Even with an emulator you are going to want to burn a chip once you are done tuning (for the moment) the emulator is great but you won't want to have it installed all the time.
GD
Old Jun 30, 2017 | 09:16 PM
Car: 1987 IROC Z28
99% sure ignition was off... battery was not disconnected however.
could it be fried from datalogging with the 10k resistor last night?
Old Jun 30, 2017 | 09:18 PM
Car: 1987 IROC Z28
GD
I've heard of many cases where people leave it in no problem. But i do understand id need to keep all my bins saved in case the emulator clears.
but i agree once I'm done tuning ill get some eeproms and burn a semi-permanent chip.
thanks man
Old Jul 7, 2017 | 11:36 AM
Car: 1987 IROC Z28
chip burning supplies arrived today from Moates... will first burn a chip with a stock bin and see if the car runs.
Old Jul 14, 2017 | 05:37 PM
Car: 1987 IROC Z28
I fried the memcal.
TunedPerformance sent me a replacement memcal and it runs great. No codes. Now time to tune
