I need help with a datalog issue
Car: 1989 Camaro
Engine: 383
I'm not sure what has changed or why but I have lost my WB in my data feed. I have swapped LC1's, swapped ECMs. downloaded the lastest S_AUJP files and nothing has helped. The WB is plugged into F14 just like it has been since I swapped over to the 7730. I can swap F14 and F15 pins and see the voltage for the WB on F15 but still nothing on F14 from the MAP(I thinks what F15 was). I tried the chip test and didn't get any voltage (assuming I was doing it correctly)so I swapped ECMs and still nothing.
I can flash in Code $59 and the WB reads out just fine hooked to the same F14 pin. I don't know how to move forward from here, any ideas?
The attached file are what I have been running. as well as the $59 used that actually worked. 383.bin is for S_AUJP and Twin Turbo$59.
Car: 1989 Camaro
Engine: 383
Re: I need help with a datalog issue
ULTM8Z, Thanks for trying to help.
I had it working fine after the 7730 swap over a year ago but a few months back my hard drive crashed and I lost all of my files. I wasn't worried about Tunerpro because I knew I could download everything for here or gearheadefi then download my tune from the ostrich and be right back where I was. Everything worked fine except the WB feed. I have made sure only one WB option was checked as well as b7 unchecked. I have even tried every option one at a time to see if I get anything and still nothing. I call myself checking any setting WB related and even found a post by JP with detailed instructions. I posted here hoping someone would mention something I may be overlooking.
I did notice a newer version of S_AUJP had been released since I first downloaded the files. I guess its possible there is a problem there but surly someone else would have noticed the lack of WB feed by now.
Moving to pin A3 could be a simple fix but then I would have issues with code $59 not being on pin F14. Maybe I should pick one code and stick with it.
Thanks again,
Dewayne
Thanks again,
Dewayne
Car: 1989 Camaro
Engine: 383
I didn't think you were, I was just stating some of the things I have tried and kinda thinking out loud.
I noticed the ALDL patch always shows "NOT Patched" even after I hit patch and save. I'm not sure what it is supposed to change but its just one more item I have looked at.
MdFormula350
Oct 28, 2005 10:58 PM
