BPC/VAC table vs WUD
Old Apr 21, 2018 | 02:41 PM
chevy383camaro's Avatar
Car: 1990 camaro rs convertible
Engine: 383
Axle/Gears: 7 5/8 3.42 auburn LSD
hey guys quick question on the EBL utility lets say 61lb injectors at 25 psi gives you a BPC value of 108. If you click the Vacuum reference tab it changes based on engine vacuum obviously. My question is when running vacuum reference 0 KPA is still 108 BPC but 80KPA is now 147 BPC is The KPA reading in the table opposite of your KPA reading in the WUD? does 80KPA on the bpc table mean 20 KPA (high engine vacuum) on the WUD like at idle. and 0 KPA on the BPC Table mean 100 KPA (Low engine vacuum) on the WUD like durring WOT?
Old Apr 21, 2018 | 05:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: BPC/VAC table vs WUD
With a VRFPR the higher the manifold vacuum the lower the fuel pressure.
The lower the fuel pressure the higher the BPC value needs to be to supply the engine with enough (proper mass) of fuel.
Old Apr 22, 2018 | 09:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by chevy383camaro
...The KPA reading in the table opposite of your KPA reading in the WUD? does 80KPA on the bpc table mean 20 KPA (high engine vacuum) on the WUD like at idle. and 0 KPA on the BPC Table mean 100 KPA (Low engine vacuum) on the WUD like durring WOT?
The MAP value shown on the WUD is manifold pressure. At sea level with standard air it is about 104 KPa.
Manifold vacuum is the opposite. The ECM calculates it by subtracting the current MAP reading from the barometric pressure. So if baro is 104 KPa and the manifold pressure is 70 KPa, then the vacuum is: 104 - 70 = 34 KPa
RBob.
Old Apr 22, 2018 | 09:35 AM
Engine: 383
Thanks Rbob for clarifying that for me 👍
mike22115
Feb 17, 2016 08:16 PM
kataklysm01
Dec 3, 2013 09:32 AM
Ronny
Jul 3, 2008 09:33 AM
Ronny
16
May 31, 2008 09:41 AM
Ronny
Apr 12, 2007 11:20 AM
