Looking for the right BIN, XDF, and ADX or ADS File - 87 Camaro 350
Car: 1987 Camaro IROC-Z
Engine: 5.7
Axle/Gears: 3.70
Good Afternoon Everyone. I am just getting started with this programming PROM thing. I can't seem to get off the right foot and find the correct files for Tuner Pro RT. I was reading the how to stickies and I need the BIN file, XDF, and ADX (or ADS) file to get going. But I cannot find this for the 1987 Camaro 350 5.7 TPI. I looked on all the linked websites, this is most likely due to my experience in what work with what. Any help is appreciated. Thank you very much in advance for the help.
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Re: Looking for the right BIN, XDF, and ADX or ADS File - 87 Camaro 350
Download the ARAP.bin and 32B xdf from TunerPro.net. There is a corresponding ads file that you can save and use tunerpro to convert to adx. I'm guessing you have the 165 ecm? Are you running a MAF set up or SD?
Car: check
Engine: check
Transmission: check
If you go with the suggested ARAP BIN, need to use mask $6E stuff. It is a different calibration layout.
RBob.
Engine: SBC 350
Looks like I’ll need to make some changes. Thanks!
Engine: 5.7
Axle/Gears: 3.70
Thank you! How do you download the ads file from tuner pro? It keeps only opening in a new tab from the browser. Thanks!
Engine: 5.7
Axle/Gears: 3.70
Thank you. I obviously have a problem reading well.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I don’t know if there is a issue with the 32 and 32b ads files. I tried to convert them to adx and it seems like they might be corrupt. You should start with using $6e after you update the .bin
Engine: Lb9
Transmission: M20
$6e adx and bins
http://www.gearhead-efi.com/Fuel-Inj...Information-6E
A $32b ads you can try
http://www.gearhead-efi.com/Fuel-Inj...nformation-32B
Engine: 5.7
Axle/Gears: 3.70
$6e adx and bins
Thank you !
