First steps
Old Feb 26, 2019 | 06:38 PM
  #51
cpalmaccio1@gma's Avatar
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Moates is taking it back with a full refund. I'll order the ebl. I take it not hard to install?
Old Feb 26, 2019 | 06:41 PM
  #52
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: First steps
Just alittle soldering, or you can send in your ecm.
http://www.dynamicefi.com/EBL_P4_Install.php
hopefully you still have your anjf or aujp memcal for knock sensor function.
Old Feb 26, 2019 | 10:53 PM
  #53
GeneralDisorder's Avatar
Re: First steps
If you buy the fully modified ECM from them I believe it's plug and play for you since you are already running the 7730 ECM stock.
GD
Old Feb 27, 2019 | 08:56 AM
  #54
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Do I need to keep the adl1 cabl ?
Old Feb 27, 2019 | 10:42 AM
  #55
Engine: Lb9
Transmission: M20
Re: First steps
The aldl1 cable you can buy separately. You need a xtreme aldl or a 12 pin cable from aldlcables.com.
http://aldlcable.com/
http://www.moates.net/aldu1-and-cabl....html?cPath=64
Old Feb 27, 2019 | 11:06 AM
  #56
Engine: Lb9
Transmission: M20
Re: First steps
Never mind the above
The ebl comes with a comm usb cable
Old Feb 27, 2019 | 11:33 AM
  #57
Re: First steps
The EBL doesn't use the ALDL at all. It does everything through an included USB cable that plugs into a remote cable that originates from the ECM case and has a headphone style jack that you can stash easily.
GD
Old Feb 27, 2019 | 12:14 PM
  #58
Engine: Lb9
Transmission: M20
Re: First steps
You can check with rbob but I think this is a good knock filter
https://www.ebay.com/itm/16177700-1994-1995-LT1-Firebird-Camaro-5-7L-Knock-module/183537848369?epid=19005497959&hash=item2abbb55031:g:lcsAAOSw0ZRb7cPw:sc:USPSPriority!20876!US!-1
You can always use your memcal but I think the cover of the ecm needs to stay off or the blue cover needs to stay off the memcal. The knock filter on your memcal should have a second digit of R . Rbob doesn’t agree with the identification but even speed density memcal I have seen has a r for the second digit. If you don’t have this r the memcal has been swapped out and the knock filter will not work and you might get false knock. If you did a exchange with Scott you might have gotten a v6 memcal. I heard he uses them instead of v8 ones. The knock filter will not work properly.
Old Feb 27, 2019 | 12:23 PM
  #59
Engine: Lb9
Transmission: M20
Re: First steps
Old Feb 27, 2019 | 02:34 PM
  #60
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
why would I need a knock filter
Old Feb 27, 2019 | 02:38 PM
  #61
Engine: Lb9
Transmission: M20
Re: First steps
To retard the timing if knock occurs. You don’t have to have one you can turn it off in the tune.
Engine pinging can damage your engine.
Old Feb 27, 2019 | 02:47 PM
  #62
Re: First steps
You can tune it like the old days and listen for ping then back off the timing. Some of these (like mine) old knock control systems are pretty useless at this stage - generating a lot of false knock events and ultimately I just had to disable it and do it old school style. The small block is more tolerant of light detonation than some newer engines as it was built prior to the advent of knock control systems and some detonation (often inaudible) was just going to be a fact of daily life for them. I wouldn't overly worry about it. Many people run with it shut off.
GD
Old Feb 27, 2019 | 03:05 PM
  #63
Engine: Lb9
Transmission: M20
Re: First steps
Any idea why your getting false knock ?
I have heard some headers can cause this as well as valve train noise (roller rockers).
Old Feb 27, 2019 | 03:21 PM
  #64
Re: First steps
Not really. But yeah I do have headers and 1.6 roller tip rockers. Also my trans is built, shifts hard, and 3000 stall converter. I haven't figure out what sets it off but I can pull 10+ degrees out across the board and it has no effect on the knock counts. It's pretty hard to determine what's causing the knock sensor to go off when it only occurs under load at 2800+ rpm.
GD
Old Feb 28, 2019 | 02:33 PM
  #65
Engine: Lb9
Transmission: M20
Re: First steps
I would still be inclined to give a knock sensor a try. If false knock is reporting than disable it.
Old Mar 7, 2019 | 02:31 PM
  #66
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
It should be the 7730 ecm correct
Old Mar 7, 2019 | 02:39 PM
  #67
Engine: Lb9
Transmission: M20
Re: First steps
Yes, or a superseded number 77-7730, 16196344,16198262 or 88999196
Old Mar 7, 2019 | 02:42 PM
  #68
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Just ordered the ebl. If you don't mind I'll notify you when installed for help tuning
Old Mar 7, 2019 | 02:56 PM
  #69
Engine: Lb9
Transmission: M20
Re: First steps
I’m no expert on the ebl, you should start your own thread to get started.
There is not a 350 aluminum head automatic tune to start with. You might want to start with 3005 tune and modify the spark timing tables.
To start off you should disable vats if needed, recurve timing table.
set your cid and injector constant. Set the injector offsets then start to do ve learns.
Gd has more experience with the ebl than I do.
Old Mar 7, 2019 | 03:02 PM
  #70
Engine: Lb9
Transmission: M20
Re: First steps
Anht spark tables
http://ultm8z.com/DIY%20Tuning.htm
This is a $8d mask
Old Mar 7, 2019 | 06:00 PM
  #71
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
What wb o2 sensor was recommended again
Old Mar 7, 2019 | 06:20 PM
  #72
Engine: Lb9
Transmission: M20
Re: First steps
You might want to ask rbob but innovative makes good products.
https://www.innovatemotorsports.com/products/lc2.php
Old Mar 21, 2019 | 09:21 AM
  #73
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Okay where do i adjust cold and hot idle speed in tuner pro. I adjusted it in the idle vs temp column it doesn't change the speed and if i get drastic with the incremental change the car wont start. I tried to adjust cold idle to 1000 and warm idle to 850 and then the car wont start
Old Mar 21, 2019 | 12:00 PM
  #74
Engine: Lb9
Transmission: M20
Re: First steps
Are you sure your using the correct xdf ?
Old Mar 21, 2019 | 12:03 PM
  #75
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Are you sure your using the correct adx ?
I used the 3005 ebl bin. Copied scotts main and extended spark tables. Then ran about 12 ve learns in idle. Cleaned up the idle allot. Still runs Rich. There surge is just about gone. I need to figure out how to lean it at idle and raise idle to 800. Btw running the innovate lc2 wb
Old Mar 21, 2019 | 12:07 PM
  #76
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: First steps
Welcome aboard the EBL express...
These control your RPM idle command based on temperature;
IAC Speed - Park/Neutral
IAC Speed - Drive
- Rob
Old Mar 21, 2019 | 02:57 PM
  #77
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Ok i am losing my dam mind here. I am simplyt tryingto raise the idle. I adjust the idle speed vs temp parameter and then the vehicle will not start
This is what its set at. The vehicle runs with low idle like this. If i try to set the appropriate temp to 800 rpm the car wont even start.
Old Mar 21, 2019 | 02:59 PM
  #78
Engine: Lb9
Transmission: M20
Re: First steps
IAC Speed - Drive
- Rob
Do what rob suggested
Old Mar 21, 2019 | 03:01 PM
  #79
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
I did.... Then the car wont even start when adjusted to 800 rpm
Old Mar 21, 2019 | 03:17 PM
  #80
Re: First steps
When it's idling - what are the IAC steps at?
GD
Old Mar 21, 2019 | 03:19 PM
  #81
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
GD
When I get back home later i will try again and post more info. I'm sorry to be a pia but it's like I'm reading Greek
Old Mar 21, 2019 | 03:35 PM
  #82
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: First steps
Wrong XDF file, check the TunerPro title bar in the above image. Also note how the entries in that table are foo. Use everything that was supplied with the EBL P4 system.
RBob.
Old Mar 21, 2019 | 03:41 PM
  #83
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
RBob.
That title is the bin i was comparing it to....one sent by scott hansen. That table is the original table that came with the ebl. When i try to adjust those values the car wont run.
Old Mar 21, 2019 | 04:02 PM
  #84
Re: First steps
You have the wrong definition file for the EBL system loaded into tunerpro - when you change the table you are actually changing unknown areas of the ROM image and thereby contaminating it and causing a no-start. Those values in your RPM vs. CT table are WAY off the wall and make no sense. The engine wouldn't even be cable of idling at 125 RPM.
GD
Old Mar 21, 2019 | 04:05 PM
  #85
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
GD
Going to scrap and start again
Old Mar 21, 2019 | 08:57 PM
  #86
Re: First steps
Not sure what you're doing or did, did you try uploading a P4 bin with a Flash XDF by chance, because those numbers are way off in your supplied picture and are skewed. Just select a stock bin that is supplied (3004 or 3005) with the proper XDF supplied, then set your injector size, engine size and initial timing to match your base by hand. The engine should fire right up and idle decently provided your engine is mechanically sound.
- Rob
Old Mar 21, 2019 | 08:59 PM
  #87
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Not sure what you're doing or did, did you try uploading a P4 bin with a Flash XDF by chance, because those numbers are way off in your supplied picture and are skewed. Just select a stock bin that is supplied (3004 or 3005), set your injector size, engine size and initial timing to match your base by hand. The engine should fire right up provided your engine is mechanically sound.
- Rob
I think i got it. I didn't know i have to load the xdf AND the bin. I didn't understand the difference
Old Mar 21, 2019 | 10:27 PM
  #88
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Ok I found out where I was a dumbass thank you everyone for your patience. I have the correct xdf and loaded a bin with the spark tables scott sent me. Was surging at idle I ran a bunch of ve learns and it is now idling ok. A few observations. It is really rich. The wb says it isnt but i can smell it. Also I noticed that the closed loop isnt lit on the wud. I assume thus is an issue should I/ How do i correct the closed loop and rich at idle. Attached is my current bin and a data log at idle. Thank you all for your patience I actually feel I have a shot at pulling this off now
File Type: bin
Old Mar 21, 2019 | 10:33 PM
  #89
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
I can't get the datalog to load here is a pic
Old Mar 21, 2019 | 11:03 PM
  #90
Re: First steps
It's not going into closed loop because your narrow band primary O2 sensor is stuck at about 475 mV. The ECU assumes this means it's not up to temp yet because at the AFR's being reported by the wideband the narrow band O2 should be around 900 mV indicating much richer than it currently does. I would say it's either broken or you didn't wait long enough for it to heat up. Try holding the RPM up around 2500 for a minute or two and see if it comes online after that.
If the run-time really is only 30 seconds - that's not long enough go bring the O2 up to temp. It's going to take minutes to enter closed loop. If you running a factory thermostat then 186 degree coolant temp means it has been running for a bit but it's not fully up to temp. You should wait about 5 minutes and try revving it before you determine it's not going to go closed loop.
GD
Old Mar 21, 2019 | 11:05 PM
  #91
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
GD
Im using a wb innovate lc2 i think i just read that with a wb it won't go into closed loop.
Old Mar 21, 2019 | 11:12 PM
  #92
Re: First steps
The wideband is for tuning. It doesn't control the feedback loop. The narrow band does. Unless you have specifically disabled closed loop for wideband VE learning.
GD
Old Mar 21, 2019 | 11:15 PM
  #93
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
GD
I no longer have the nb on the car i put the wb in its place. Is this correct?
Old Mar 21, 2019 | 11:19 PM
  #94
Re: First steps
Well no, not exactly. The narrow band should be used for closed loop fuel control. The wideband connects to an entirely different set of ECM inputs. You should have both. I believe some widebands can also simulate a narrow band output but wideband sensors (aftermarket) can be relatively unreliable and this would be a mistake in my opinion.
GD
Old Mar 23, 2019 | 07:24 AM
  #95
MrWillys's Avatar
Re: First steps
Charles, I would suggest you go through each table and compare with what i created for you. My bin should only need VE tuning. My spark map should be used and the PE vs spark add should be zero'd out. A corvette bin spark map should never be considered with the cam you're using. The spark map i use is from a 20 year old TPiS bin when they actually knew how to tune. Scott
Old Mar 23, 2019 | 07:42 AM
  #96
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
I used your spark map and the car runs. For some reason when i copy the rest of the bin the car wont start. I don't know what value actually causes the bin not to work
Old Mar 23, 2019 | 10:45 AM
  #97
Engine: Lb9
Transmission: M20
Re: First steps
I believe Your comparing two different masks. You can ask rbob how that works.
I think you will have to copy and paste the information after each bin is opened in its appropriate mask. You can load the dxf and bin easily with the tool bar resents.
Old Mar 23, 2019 | 10:54 AM
  #98
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
The car runs with scotts spark tables. I tried copying all the info from his bin to mine via copy and paste. When i do it won't start. Something I'm copying isn't working with the ebl. I am taking a wild guess that it has something to do with prom id mask or check sum i don't know what those exactly are like i said wild guess
Old Mar 23, 2019 | 11:03 AM
  #99
MrWillys's Avatar
Re: First steps
Under Tools, Custom Tools, New Tunerpro Instance you can have 2 windows open to compare. make sure to use my Spark Advance closed throttle vs RPM table.
Old Mar 23, 2019 | 12:02 PM
  #100
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Do i only copy all the tables or the scalars too?
