First steps
Old Mar 23, 2019 | 12:35 PM
  #101
GeneralDisorder's Avatar
Re: First steps
Some scalars will need changed and some will not. If you have a bin that runs don't mess with the PROM ID or the checksum - the checksum for one thing is automatically updated by tunerpro when you save the bin.
You should read through RBob's tuning guide so you understand what needs to be changed and why. And before you change any values look them up in the reference so you fully understand what it is you are changing and what effects it will have. This is a learning process and it's not going to happen immediately.
Did you correct the oxygen sensor situation?
GD
Old Mar 23, 2019 | 12:40 PM
  #102
cpalmaccio1@gma's Avatar
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
GD
Working on the 02 thing now. Scott wrote a good bin. It ran ok just needed tweeked. I'm trying to get to work with the ebl
Old Mar 23, 2019 | 01:01 PM
  #103
MrWillys's Avatar
Re: First steps
Originally Posted by cpalmaccio1@gma
Do i only copy all the tables or the scalars too?
Copy everything you can. Then do a datalog and play it back with the history table open and set to history averages in the top box. Then work your ve tables. say you have a cell that is 118 divide this by 124 and use it to multipy the ve value of the same cell. I work everything to within 124 and 128.
Old Mar 23, 2019 | 05:00 PM
  #104
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: First steps
Wow, this thread isn't going too well.
First off, the EBL P4 isn't maskid $8D. So can't copy directly from the former BIN to the EBL BIN. To explain better, the XDF file is based on the calibration layout, which do not match between $8D and the EBL Flash products.
That is like using a road map of Toledo to navigate Boston.
If you want to use the SA tables from the previous $8D BIN you will need to manually copy/enter the points (by RPM & MAP) of the $8D SA table into the EBL BIN. Then interpolate the missing rows and columns and extend the SA values into the higher RPM. The EBL SA table(s) are of higher resolution and extend to a higher RPM then $8D.
And, they are not in the same location of the BIN as each other.
As for the VE (Mr ******), just do auto VE Learns. It makes quick work of the VE table(s). More so when using a WB setup.
Charles, for best WB VE Learn coverage, also disable the highway lean cruise mode. Set this parameter to 150° C:
HiWy - Min Coolant
Can re-enable it once most tuning has been completed.
Usually need to disable closed loop, but without a NB sensor it won't go into closed loop anyway. If you want to post a .dat data log, zip it first.
RBob.
Old Mar 23, 2019 | 05:05 PM
  #105
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
HiWy - Min Coolant
RBob.
Ok manually copy and paste Scott's sa tables?
Disable highway lean
I hooked the narrow band back up and installed the wb so i will have to manually disable closed loop in the tune
Old Mar 23, 2019 | 06:41 PM
  #106
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
I think I'm finally getting somewhere. Used ****** spark tables and did what rbob said. Idles better right off the bat and not as rich. Will post datalog after a few ve learns in idle
One question. When do i enable closed loop again?
Old Mar 23, 2019 | 06:54 PM
  #107
Re: First steps
You enable closed loop after you do the wideband VE learns. RBob also suggests doing a few narrow band VE learns again after enabling closed loop.
You really don't want to run open loop all the time. There are varying conditions where the speed density system gets pretty far out of whack if you don't have the narrow band feedback (such as hot soak restarts). I've seen my AFR's go crazy lean sitting in a hot drive-through with closed loop disabled. Makes the idle and the off-idle progression pretty terrible. The reality is that having the magic 128 BLM at all times isn't really possible or neccessary. The system has the ability to adjust for a reason - because it just wouldn't work worth a darn if it didn't.
GD
Old Mar 23, 2019 | 06:58 PM
  #108
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
GD
So ve learns while driving need to be done in open loop as well?
Old Mar 23, 2019 | 07:49 PM
  #109
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Made alot of progress today thank you guys. Car idles better than ever. Only issue is when i put in close loop I notice that every so often the idle drops to around 700 then comes back up. Any Ideas? Attached are my current bin and the data log
File Type: zip
File Type: bin
Old Mar 23, 2019 | 08:07 PM
  #110
Re: First steps
Only wideband VE learns are done in open loop. Narrow band VE learns are done in closed loop.
GD
Old Mar 24, 2019 | 09:22 AM
  #111
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
GD
Oki figured some stuff out on my own. The ve learns should take care of allot. I realized that to learn in closed loop mode i have to change the preferences in the ve learn window. Now i remember someone telling me i can use the original memcal for knock sensor and that there were other options can someone on me in the right direction for that
Old Mar 24, 2019 | 03:58 PM
  #112
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Ok this thing idles great now open and closed loop. Stalls in d and r when pressing brake hard. Any ideas what to mess with?
Old Mar 24, 2019 | 05:33 PM
  #113
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
I think i figured this out. I was getting a malf code of high map. I raised the map high limit on the ebl and it doesn't stall it now. I have a few questions now regarding some observations
The closed loop nb reading seems lean. On the diagnostics graph in the wud the nb is up in the 20s and the wb reads around 15 or 16 why the big difference? Which one is correct?
Also what is the correct afr in idle? I noticed i am at 15 to 17 isn't this too lean?
Old Mar 25, 2019 | 08:19 AM
  #114
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: First steps
The AFR scale is for the WB. The mV scale is for the NB.
RBob.
Old Mar 25, 2019 | 08:25 AM
  #115
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
RBob.
After playing with everything the wb read 14 ish at idle... The blm is pegged at 108. I did research and I'm sure i need to play with the 02 mv tables but not sure which direction to go
Old Mar 25, 2019 | 08:32 AM
  #116
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: First steps
The BLM is the long term fuel trim. Need to lower the VE table in the area that is causing the BLM to be 108.
RBob.
Old Mar 25, 2019 | 08:41 AM
  #117
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
RBob.
If i do that the wb goes lean like 16 or 17
Old Mar 25, 2019 | 09:01 AM
  #118
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: First steps
Does the engine still run OK? If so then don't worry about what the WB is reporting. Can also run open loop idle.
RBob.
Old Mar 25, 2019 | 09:04 AM
  #119
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
RBob.
Engine runs great either way....i was worried about a lean condition i don't want detination and i have no knock sensor with the ebl
Old Apr 13, 2019 | 06:44 PM
  #120
Car: 90 iroc z
Engine: 358 tpi
Re: First steps
Car idles and runs good now. I started tuning the high speed ve tables. I've learned that my cam overlap makes the wb useless for tuning idle and low speed tables. I used blm learns to tune those areas. I have forced open loop and disabled pe to run the high speed tables manually via wb data. My question is what is the target afr? I think i understand that the when pe engages the ecu uses the ve tables to adjust the afr the 12.8 when in pe. Does this mean i should tune the ve to stoich then let pe take it to 12.8? Am i doing this correct by having pe disabled and forced open loop?
Old Apr 13, 2019 | 06:59 PM
  #121
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: First steps
Only tune the full VE map to stoich if you're a stickler for the numbers being accurate, which is what I normally do. It's a waste of time though. Just smooth out the VE tables based on the areas that you know are already stoich, then work your way up the map increasing injector duty cycle in a smooth and linear fashion. It doesn't have to be perfect, again, unless you're a stickler. Anyways, just target your PE air/fuel, and using the wideband at those upper RPM's, change the PE accordingly until the wideband reads what you want it to read,because that is all that really matters in the end.
- Rob
Old Apr 13, 2019 | 08:04 PM
  #122
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: First steps
How do you like the ebl compared to the tune you had before ?
better power/throttle response?
Old Apr 13, 2019 | 09:49 PM
  #123
Re: First steps
Edit: That question wasn't for me, deleting post...
- Rob
Red_Bully
Mar 31, 2007 03:00 PM
Red_Bully
Aftermarket Product Review
Mar 29, 2007 11:50 PM
onebluemcm
Oct 25, 2003 05:06 PM
irocnroll89
May 25, 2003 07:27 AM
