Sensors used during cranking
Old Mar 20, 2020 | 09:23 AM
frebor72's Avatar
Hi
Iīve searched the forum but couldnīt find the correct answer. The reason is that I experiencing a rich start that I want to adress by taking fuel out. Or add air...
So, what sensors are used during cranking?
Some I know
CTS
IAC (maybe not a sensor)
TPS
Old Mar 20, 2020 | 09:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Sensors used during cranking
It varies according to which ECM/MaskID is in play. For your '87 the crank sensor (distributor), CTS, and TPS are used. The MAF is ignored until the engine is running (over 300 RPM).
You are correct about the IAC not being a sensor. It is controlled by the ECM by bypass air around the throttle blades.
RBob.
Old Mar 20, 2020 | 10:02 AM
frebor72's Avatar
Thanks!
Itīs very good to know that the MAF is not used. That was one of my questions. Now I need to rule out problems with fuel pressure and ignition. Then I will try to make adjustments in the prom again
/Fredrik
lickem
Apr 26, 2011 04:53 PM
ptaheavy
May 15, 2010 08:28 AM
Dean_GTA
Aug 31, 2008 11:15 AM
pa_richardson
May 26, 2008 04:51 PM
anything-z
Oct 22, 2005 11:05 AM
