hunting
Old May 10, 2010 | 04:17 PM
ptaheavy's Avatar
hunting
hello to all. i have a 91 l98 tpi sitting in a 71 ss elcamino. i have been fighting a hunting issue that i just cant seem to catch. the computer does not throw any codes at me, i have changed to o2 sensor. coolant temp sensor, map and air charge. once the engines comes to temp the idle wont stabilize. i have removed the injectors and applied dc power to make sure that they actuate, have good pressure on the rail. the car runs rich!!! when i have removed the plugs they are all wet. i dont have a scanner but have taken a timing light to each plug wire and they appear to have the same reaction through the gun ( kinda backyard )
could this be a injector issue?
Old May 10, 2010 | 07:04 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Re: hunting
Have you properly set the IAC valve and TPS? Check out this tech article for instructions on how to do it.
Old May 10, 2010 | 07:30 PM
ptaheavy's Avatar
Re: hunting
the tps on this intake is non adjustable. i think it is off of the zr1. iac i thought was plug and play
Old May 10, 2010 | 07:35 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Re: hunting
Gotcha on the TPS. The IAC itself just screws in, but the minimum air screw needs to be set so that the IAC isn't bottomed out in one direction or the other.
Old May 14, 2010 | 04:46 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: hunting
If it's a TPI TPS sensor it shuld be adjustable. Why would you put a ZR1 TPS sensor on in the first place? Clearly it's calibrated differently. First thing I would do is get an adjustable, factory unit for that year TPI setup. Then adjust it to the proper calibration setting. Also adjust the IAC for minimum air as mentioned in a previous post. You may find that you replaced several sensors unnecessarily
Will
Old May 15, 2010 | 08:28 AM
ptaheavy's Avatar
Re: hunting
with regards to the sensors, they were part of the harness that was made for the install. i have a replacement tps that is adjustable, when i stalled it it did not resolve the problem, so i put the original back on and the replacement is in the tool box. the iac sensor was only removed and cleaned when i had the injection apart . it's when the car sat for 6 months this turd appeared. all of the plugs are wet when removed, and still no codes anywhere. i have purchased a set of bosh III's that are going in today.
fingers and toes crossed!
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
bbsr72
Apr 2, 2016 09:12 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BDR
Nov 7, 2015 03:05 PM
89newfun
Sep 16, 2015 09:28 AM
