Options for CCC Carb chips in an 86 LG4 with L69 cam?
Old May 23, 2020 | 09:14 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
What are my options for chip burning for a 1986 LG4 manual with flat top pistons and L69 camshaft?
It originally had a 169 ECM and the stock FFA chip. I swapped in an 079 ECM from an 88 Monte Carlo L69 with an automatic. I can't really seem to find any information about 1986 L69 cars. Would an 1226865 ECM from an 85 L69 swap into my existing car?
I would really like do copy the timing tables from the 079 and burn my own chip but there is precious little information on how to do that with CCC carbs. I have a Burn1, ALDL cable, Bluetooth ALDL, but most of my experience is with 165 TPI cars, which there is plenty of information about.
Old May 23, 2020 | 01:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Options for CCC Carb chips in an 86 LG4 with L69 cam?
In the Tuning Guide Book sticky there is a CCC ECM section that has some decent links. Should be helpful.
RBob.
ur7x
22
Jun 25, 2024 08:06 PM
w41duvernay
Mar 30, 2016 03:03 PM
Project"Z"
Carburetors
Jan 4, 2013 08:16 PM
HasseO
Carburetors
Nov 18, 2008 05:52 PM
