ho compared to lg4
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
ho compared to lg4
Hi,
Have made the following mods to my lg4: mild cam, dual snorkle setup, l69 manifolds (the best castings) 3" exhaust, high flow cat.
Now what about the carb? Can I easily modify it to resemble the l69 carb, or would it be better to find a good l69 carb?And what about the computer? Will I be able to use a l69 chip with my lg4 ecm?
Hasse
Hasse
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ho compared to lg4
,Have made the following mods to my lg4: mild cam, dual snorkle setup, l69 manifolds (the best castings) 3" exhaust, high flow cat.
Both carbs have the same capability, basically."
I did the AV tension mod and swapped out the stock rods and hangers for the L69. I didn't have the tab that five7 comments on either.
Here's the entire link:
https://www.thirdgen.org/forums/faq-...5-engines.html
JamesC
Transmission: 4L80E/4L80E
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Regarding the carb, I think Ill change the secondary rods/hanger. Doesnt seem too difficult but I guess I will have to be careful.... I have read different recommendations, but most often DR or CK rods. Will any of these work well with CCC and what hangers should I try?
JamesC
83 Crossfire TA
Sep 18, 2015 12:01 PM
