7-Pin Module Help
Old Jan 26, 2021 | 08:49 PM
BB72Camaro's Avatar
7-Pin Module Help
I currently have a 4-pin HEI distributor.
I want to convert to a 7-pin module so I can get a clean square wave RPM signal for my Fitech Meanstreet.
Research says that pins C and A on the Weatherpack plug need to be jumped together for the distributor to work. These pins correspond to pins B and E on the module per the diagram I found.
What does jumpering these pins together do electronically to make the distributor function without the EST module?
If I jumper these pins, can I still get a square wave signal from pin R?
Also, will the distributor still function normally as if it still had the 4-pin module?
Just to clarify, I want to retain the original mechanical and vacuum advance. I am just looking for a clean square wave RPM signal for the Fitech ECM. This particular Fitech is not capable of timing control.
Old Jan 27, 2021 | 09:53 PM
GeneralDisorder's Avatar
Re: 7-Pin Module Help
Just use the coil negative. That is the RPM signal.
GD
AssaulT/A
Alternative Port EFI Intakes
43
Apr 16, 2018 06:31 PM
bigozzyfan4life
Jun 1, 2008 02:22 PM
TPI TERR
Feb 3, 2007 01:26 AM
subliminal
Aug 22, 2006 05:19 PM
