High commanded AFR in low rpm open loop
Old Jan 24, 2021 | 02:24 PM
htrdbmr's Avatar
Car: BMW 735
Engine: 383 W/ SUPERAM
Axle/Gears: 3.64
I'm using saujp v5, and as the title states, the commanded AFR after initial startup will be from 15 to18 at idle prior to going into closed loop. It's set to go closed loop at 115 deg, Once [n closed loop the commanded AFR will be normal. Sorry for the confusion, but the Bucs scored their first TD as I was writing this.
Old Jan 29, 2021 | 10:29 AM
htrdbmr's Avatar
Car: BMW 735
Axle/Gears: 3.64
Re: High commanded AFR in low rpm open loop
Problem solved, thanks.
lakeffect2
Aug 8, 2011 08:02 AM
conv90
May 21, 2008 09:05 AM
5.7RamJet
Jun 5, 2007 08:47 AM
Binder
Apr 6, 2007 05:05 PM
