Zeitronix WB not working in S_AUJP v6
Old Mar 25, 2021 | 05:36 PM
355sbcTPI's Avatar
Car: 1983 Camaro Z28
Engine: 355 Tuned Port with Vortec Heads
Transmission: T56 six speed
Axle/Gears: 373 10-bolt
Hello, I just recently upgraded my '165 MAF series ecm to '730 MAP swap.
I have a 355 TPI with Vortec heads, SLP runners, Ford 30lb BB302 injectors, Comp Cam XR276HR-12
I am using the S_AUJP v6 for the first time so please be easy on me! I am also running Moates Ostrich 2.0 which is awesome by the way.
First start up was great actually...my motor idled pretty decent with some of the basic changes I made in the chip beforehand.
I've read through the instructions on WB O2 support but I think I am doing something wrong??? I can't get an AFR in Tunerpro RT.
I have a Zeitronix Zt-2 WB controller and I have hooked it up to pin F14 for sensor #1. I am also sending a simulated NBo2 signal to the ecm which is working properly.
I have selected my WB controller on the Flags "WB OPT 1, b7"
Am I supposed to enter a formula for the WB I have? Is there other Flags that I need to check in the Bin/Xdf?
When I run the Zeitronix Datalogger software by itself...It works.
Anyway, thanks for your time.
Old Mar 25, 2021 | 06:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Zeitronix WB not working in S_AUJP v6
Might want to ask here if no response from 84elky I would assume like $6e this $8d
style adx would need the correct equation to work .
https://www.thirdgen.org/forums/diy-...-released.html
Green89IROC305
May 8, 2019 12:38 PM
coolrimsatleast
Apr 11, 2009 11:01 PM
phoronZ
May 24, 2006 08:45 AM
pellmanm
May 16, 2005 11:16 AM
Viprklr
Nov 7, 2002 06:31 AM
