hypertech memcal
Old Jan 17, 2002 | 09:59 PM
wuter's Avatar
hypertech memcal
i opened my hypertech calpack to attempt to solder a zif socket in and noticed it had no memcal just a 28 pin eprom, i had to modify the stock chip because of this, does anyone know why it doesnt have one.
Old Jan 18, 2002 | 09:04 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I may be confused here with what you are trying to describe.
This is what I know about my Hypertech memcal:
My '87 TPI Hypertech memcal is the large plastic thing that plugs into my ECM unit. If I remove the plastic cover on the memcal unit, I see a 28 pin eprom. This eprom is not soldered into the memcal unit. Because the eprom is easily removed and replace with another eprom with soldering, I have been using the Hyperteck memcal unit with my modified eprom to test my car's performance.
There is no need for me to solder a zif socket into the Hypertech memcal unit. I am very carefull to line up all of the little prongs of the eprom and press it in place.
I'm sorry if this does not help you.
Doc
88SS6SPEED
Nov 11, 2015 07:05 AM
KO1
16
Oct 15, 2015 05:00 PM
lethaldomestics
Sep 21, 2015 01:18 PM
RyanJB
Sep 2, 2015 01:27 PM
