TPS Sensor
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPS Sensor
For some reason elongated hole 85-89 tps are actually cheaper than 90-92
, but with some manufacturers, sometimes even Delco, you may have to enlarge one or both of the mounting screw holes to ensure it's positioned so you're getting the required 0.54+v at closed throttle.
