EBL Flash and Windows 11
I had just done my Windows 11 install and everything seemed OK. That is, until I tried to load a new bin file into my ECM. I have the older model EBL Flash that uses a serial to USB adapter and I could not find a Windows 11 driver that was compatible with my adapter. There is probably a work around but I will let someone else figure that out. I did find that it it really easy to go back to windows 10 so all is good now. As Roseanne Roseannadanna said " it just goes to show you,— if it’s not one thing, it's another. but it's always something"
Car: check
Engine: check
Transmission: check
Re: EBL Flash and Windows 11
If this is an FTDI Serial/USB adapter cable, driver(s) can be found here:
https://ftdichip.com/drivers/vcp-drivers/
Not only the latest, but they are now providing access to the older drivers. Can't beat the FTDI folks, they do produce good products....
RBob.
RBob.
I am using a Prolific PL2303 and the latest driver for windows 11 did not work for me. My research found other users reported a problem with it also. I just wanted to remind people that even Microsoft warns some hardware and apps may not be compatible with windows 11. I 'd rather let others work the bugs out. I am using this cable . I like it because the adapters are secured with zip ties under the passenger seat. Only the cable with the usb connector are visible by the center console and there is less strain on the usb port while plugged in to the pc.
Car: check
Engine: check
Transmission: check
Yes, the Prolific chip set leaves a bit to be desired. We always used USB/Serial cables with FTDI chip sets. Along with implementing FTDI chips into products.
It is good that you got it going...
RBob.
RBob.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
RBob.
RBob.
Car: check
Engine: check
Transmission: check
It's frustrating when new OS installations throw a wrench in our plans! Rolling back to Windows 10 sounds like a sensible solution for now. If you're ever considering another upgrade, keeping an eye out for windows 11 cheap deals could be helpful. As Roseanne Roseannadanna wisely said, it's always something, but we find a way to make it work!
