TC Injector Constant for 24# SVO injector?
Old Jan 18, 2002 | 03:51 AM
Wilson's Avatar
Well, I got a 93 Camaro but its uses the SD ECM. So, its very similar to the 92 camaro setup. I upgrade my stock 22# injectors to 24# SVO's. Does anyone know the correct Injector Constant to use? This is what I observed from my own 93 stock chip and from 94+ PCM files.
24# RC injector constant @ 24.896
22# RC injector constant @ 24.1
What should SVO 24# run? Thanks!
Old Jan 18, 2002 | 08:55 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The 24#/hr SVO fuel injector is rated at 2.5 bars (about 37psi).
On the GM system (3.0bars or about 44psi), the SVO injector would be rated at 25.8#/hr.
I suggest that you do a search on this matter.
Doc
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
