Cold SA problem running vortec heads and $8D
Old Mar 17, 2022 | 01:22 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
I need some advice about how best to handle a SA problem. I noticed that, when cold (<45*c) my SA was retarding a bunch, like 15*. This significantly impacted the idle quality as well as made for general poor performance.
Through research I finally figured out what was causing this. As I'm running a TPI L31 (vortec heads) and then swapped in a higher stall converter, I was getting some knock retard in the high load low rpm range. So I kept reducing SA in that area (now down to 10* at 400-1000 rpm). As I did so, the problem with cold performance got worse and worse. (I think what I really need is to significantly increase AE, as it appears I'm getting a lean spike due to the converter flash at quick throttle transitions.)
Not being the sharpest knife in the drawer, it took me a while to connect these dots. The $8D code basically removes the MAP from the SA equation until > 44.5c (113f).Additionally it uses the "Spark Advance Temp. Correction Vs. Load Vs. Temp." table to further complicate matters.
Seems I have several options to choose from:
Effectively disable "Spark Advance Cold Disable Temp." by setting it to -40. What could be the downside to this option?
I could set the 100kPa SA back up to 20.4* (stock $8D) since it never actually sees 100kPa in operation.
Only other option would be to try and calculate a correction for the coolant correction bias table, though this seems awfully complicated.
Any input is welcomed.
Old Mar 17, 2022 | 02:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Cold SA problem running vortec heads and $8D
if I understand your post correctly, i believe all you need to do is play with this table. When cold you want to add spark typically, and also needs to be richer fuel wise. Idle speed should be a bit higher as well typically
at normal operating temps, you dont want any spark modifications in this table so values should be 0. At overheating temps may want to subtract some spark.
Old Mar 17, 2022 | 02:35 PM
rt66er's Avatar
Engine: L31 350 TPI
Thanks.
I believe all you need to do is play with this table. When cold you want to add spark typically...
If this is true (and I have no reason to think not) why does the $8D table pull SA in this particular region? Would this have something to do with emissions and/or cat converter?
Old Mar 17, 2022 | 03:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
It could…im not sure but it could technically put more heat inside the exhaust and thus heat the cat up quicker. Id have to see if any other adders are used anywhere else. Others may comment
Old Mar 17, 2022 | 07:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
As mentioned it is to help kick off the cat-con. Doing this SA pull dumps a lot of heat into the exhaust, which is a good thing to help a cat start to work.
As you found $8D has some strange SA functions. Best to disable the cold start SA table shenanigans. And check the stall saver SA and disable how it works. It helps stall a modified engine.
RBob.
Old Mar 17, 2022 | 08:32 PM
ULTM8Z's Avatar
I agree with RBob... $8D has too many little side tables that mess with the spark advance...
I zeroed out the Coolant Temp Correction vs Load vs Temp table. Also zeroed out the spark advance/retard vs idle speed error tables and the power enrich spark advance. Basically, I wanted the spark controlled only by the main spark advance tables.
Keeps things a little more stable at idle speeds.
Old Mar 17, 2022 | 09:16 PM
rt66er's Avatar
Engine: L31 350 TPI
Thanks for the help. Much appreciated.
ULTM8Z
Jun 1, 2008 01:19 PM
mike1986fyrbird
16
Mar 14, 2007 05:32 PM
V8Astro Captain
Oct 9, 2005 09:20 PM
11sORbust
Jan 4, 2004 04:17 PM
