$12P on 165
$12P on 165
So I had issues with maf and found I could go map with $12p. I have it running pretty good expect at times it'll randomly die. Main issue is if I hit the throttle (goose it) it'll die then when going into gear it'll die. Understand this isn't right after ether it'll find its idle run clean 14-14.7:1 then it's like the iac says nope and drops down and kills it from what I've seen. This takes about 10-15 seconds sometimes longer. I've adjusted many things and can seem to change this from timing to fuel to idle speed. I posted this on pcmhacking as well cause the Australians use $12p more then alot of us, but time difference makes it harder and I need to figure this out🤷 anyone seen anything like this? Oh I also have the baro map hooked up and uego hooked up and working properly. I can post a data log tunerpro, but I've gone through ever parameter and see nothing out of the ordinary expect the iac drop.
