Air/Fuel Ratio
Air/Fuel Ratio
What should the air/fuel ratio be? My http://www.nordskogperformance.com guage says that Stoich is 14.7/1. Is this true?
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Yes, the perfect air/fuel ratio is 14.7:1
However, the fuel never gets mixed in perfectly to burn all of the oxygen. Therefore, typically you need to run a little rich to burn all of the oxygen to develop max torque and Hp. So you should be running between 12.7 and 13.3:1 for best WOT performance.
For normal cruising around, 14.7:1 is just fine for better fuel economy, even leaner like 15.5:1 is OK.
Car: An Ol Buick
Engine: Vsick
Re: Air/Fuel Ratio
If you want a lean cruise of like mid 16s will get you better mileage.
WOT tuning is about finding what your engine combo wants.
BTW, the oem ecm toggles the AFR so that the AVERAGE is 14.7. I has to cycle rich and lean to keep the converter working
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
