EBL tuning help ..tuner pro
Old Oct 23, 2022 | 06:13 PM
drwhp's Avatar
i run a supercharged 355 with mpfi and 80 lb injectors...the problem starts intermittent either at leaving a intersection or on the highway under cruise...wide band leans out and i get a lean back fire....to stop it i just have to hit the throttle and it stops....help if you can
Old Oct 24, 2022 | 03:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL tuning help ..tuner pro
A data log would be helpful.
Is lean cruise kicking in at too low of an RPM/MPH?
RBob.
Old Oct 24, 2022 | 04:01 PM
drwhp's Avatar
i thought i had lean cruise shut off...must noticed last time i was out on the highway it went full lean ...nothing on wide band then a lean back fire then back to normal with wide band indicating normal...also tried changing afr closer to 14.7 ...will try to get more info for you ..will be taking out tomorrow to get a sticker...i will data log the ride...thanks for the reply
MrWillys
Mar 23, 2019 08:53 AM
Piston454
Feb 23, 2015 04:54 PM
jammin
Oct 10, 2008 12:57 PM
