Solved-Knock Retard Reported When No Knock Count
Old Dec 28, 2012 | 11:53 AM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
CORRECTION TO CODE ADDRESS FOR KNOCK COUNT REPORTING IN DATA STREAM
Please see changes in red in last paragraph that corrects the above address.
Well shaazaaaaam… After hours of code review, flowcharting and code simulation, I think the mystery of why Knock Retard (KR) is reported in AUJP $8d when there are no reported Knock Counts (KC) may have been solved. Likely the following will apply to other masks as well. If you have a different view, please respond.
First some background. May get a bit code geeky, but necessary for understanding the logic. Also a long post but also necessary.
To begin, the KC logic is NOT “what you see is what you get”. (RBob alluded to this years ago and again recently in other posts. Thanks RBob!). Here’s what that means. There is a difference between ACTUAL KCs detected by the sensor and those REPORTED by ALDL monitoring software (TunerCat TunerPro, etc.). The reported KC value is equivalent to 1 KC after the sensor has actually sensed 255 KCs, 2 KCs are reported after 510 KCs are actually sensed, etc. What’s happening under the covers is that there is a separate place that actual, sensed KCs are accumulated before being reported. From an Assembly language perspective, the reported KCs are stored in 0x00C1 (this could be called ‘Slow KCs’) and the actual (sensed) KCs are accumulated in 0x00C2 (call this the ‘Fast’ KCs). In the code, 0x00C1 is a 2 byte word where C1 is the MSB and C2 is the LSB. Neither byte can be more than $FF (255d), so when C2 reaches $FF, it rolls over to 0, continues to count actual KCs and increments C1 by 1. Research indicates this is apparently how most OBD I devices handle KCs. Possibly GM felt that a couple of hundred or so actual knocks was not a big deal and they would not be reported, but then a steady accumulation of them was significant and would be.
With that background, here’s what occurs that causes KR to be reported without seeing any KCs being reported. Looking at JP’s AUJP hack, the key is the ‘mul’ (multiply) instruction found in the area of code labeled with the comment “LOOK UP KNOCK ATTACK RATE vs RPM”. The ‘mul’ instruction is commented as follows (see line 8 of Code Segment 2):
mul ; KNOCK CNT * ATTACK RATE = "D"
On the surface, one would take the comment at face value and assume that “KNOCK CNT” refers to the reported KCs (C1); and if zero, the result of the multiply would be zero, and thus all the logic that follows the multiply would cause KR to be stored and reported as zero.
Ah, but remember C2, the actual sensed KCs (‘Fast’ KC). That is the value used in the multiply instruction. This can be verified by tracing backward in the hack to where KCs are detected and the LSB of L3FCA (L3FCA = Knock Sensor Input to the ECM code, see first line of Code Segment 1) is pushed to the stack (see 4th line from the bottom of Code Segment 2 = pshb). There is no other code after that pshb that affects the stack. Thus, when the following instruction is executed, (line 6 of Code Segment 2):
pulb ; GET KNOCK CNT FM STX
it is the LSB (C2 = Fast KC) that is pulled from the stack for use (and NOT C1, the reported KC value). So there could be a couple of hundred KCs actually sensed and residing in C2, but C1 would not have reported anything because 255 KCs had not yet been accumulated in C2. Now with KCs in C2 being > 0, the code that follows may (note “may”) cause a value > 0 to be stored via the ‘staa’ instruction to L00C4=Knock Retard Degrees at the last line of Code Segment 1.
And that is how I believe it works. After KR is encountered, it’s decayed to zero in the LSEG_A loop of the code.
Given this, one could change C1 to C2 at Calibration address [original=incorrect=0x8992] [correct=0x8922] which will cause the actually sensed knock counts to be reported instead of the C1 counts (thanks again RBob). Location [original=incorrect=0x8992] [correct=0x8922] is where KC is reproted in the ALDL data stream. With this change, actual KCs can be compared to when KR occurs. Granted, there might be a lot of activity reported with C2, but at least it will be “what you see is what actually happened” and not what GM wanted us to see.
Code Segment 1 (In the bin, this code precedes Code Segment 2 below)
Code:
; KNOCK MINOR LOOP
LBB59:       ldd     L3FCA                   ; READ KNOCK SENSOR INPUT    ; CRef: 0xBB53
   pshb                            ; SAVE TO STX [Tom-This is Knock Count LSB]
   psha                            ;             [Tom-This is Knock Count MSB]
   subd    *L00C1           ; CALC CURRENT KNOCK CNT = (PA3 CNT'R LAST MNR LP)
   tsta                            ; Subtract 0x00 from A, set condition codes
   beq     LBB65                   ; BR IF EQUAL TO [Tom-Branch if Z=1 meaning
                                   ;...else,
   ldab    #0xFF                   ; Val = 255, Max Value
LBB65:       pulx                            ; CRef: 0xBB61
   pshb                            ; SAVE CURRENT KNOCK COUNT TO STX
; [Tom-This is LSB of Knock Sensor Input]
   stx     *L00C1                  ; CPU PA3 CNT'R LAST MNR LP
   clra
   brset   *L0003,#0x80,LBB8A ; BR IF b7, KNOCK DISABLED, FUEL/AIR MODE WORD 1
Code Segment 2
Code:
; LOOK UP KNOCK ATTACK RATE vs RPM
; TBL = ATTACK RATE IN Deg/MSEC/0.0225,
; 400 - 4800 RPM
   ldaa    *L0057                  ; GET Scaled RPM/25
   lsra                            ; DIV BY 4 FOR LK UP, (DIVIDE BY 2 twice)
   lsra                            ;
   ldx     #L820E                  ; KNOCK ATTACK RATE vs RPM TABLE Location
   jsr     LE3D8                   ; 2D LOOK UP, NO OFF SET (Is LE3D0 in ANHT)
   pshb
   lsld                            ; MULT * 2
   adda    *L00C4                  ; SUM in L00C4
   bcc     LBBC0                   ; Branch IF NO OVER FLOW,
                                   ; ... else
   ldaa    #0xFF                   ; Val = 255, MAX
LBBC0:       psha                             ; CRef: 0xBB9D,0xBBA6,0xBBA8,0xBBBC
   brclr   *L0046,#0x20,LBBD2      ; BR IF NOT b5, POWER ENRICHMENT
                                   ; ... else
; LK UP MAX KNOCK RETARD WHILE IN PWR ENRICH ..
; vs RPM [Tom-2D Table varies from 13.54 - 16.52 Deg .vs. RPM]
   ldx     #L8218         ; MAX KNOCK RETARD WHILE IN PWR ENRICH vs RPM TABLE
   ldaa    *L0058                  ; RPM/25 (un-filt) ???
   lsra                            ; DIVIDE BY 2,  RPM/2
   ldab    #0x10                   ; Val = 16, Offset for Look Up
   jsr     LE3D4                   ; 2D LOOK UP (Is LE3CC in ANHT)
   bra     LBBDB                   ; BRANCH ALWAYS
; LK UP MAX KNOCK RETARD WHILE not IN PWR ENRICH ..
; vs MAP
LBBD2:        ldx     #L8220      ; MAX KNOCK RETARD while NOT in PWR ENRICH vs MAP TABLE
                                   ; CRef: 0xBBC1
   ldaa    *L0071                  ; NORMALIZED LOAD MAP VALUE
   lsra                            ; DIVIDE BY 2
LBBDB:        pulb                            ; CRef: 0xBBD0
   cba                             ; COMP LOOKED UP RESULT to B reg
   bcs     LBBE0                   ; BR IF B is Greater Than LOOKED UP RESULT
                                   ; .... else
   tba                             ; Transfer from Accumulator B to A
LBBE0:        staa    *L00C4                  ; KNOCK RETARD
                             ; CRef: 0xBB88,0xBB99,0xBBDD
Last edited by 84Elky; Nov 22, 2013 at 11:57 AM. Reason: Corrected Code Address of Knock Count Reporting in Data Stream
Old Oct 3, 2022 | 05:45 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Solved-Knock Retard Reported When No Knock Count
This is a 10 year old post that just answered my question. It's quite important for anyone trying to tune WOT-SA.
It does apply to mask $6E, APYS (Camaro IROC-Z, 1989, LB9, M5). On my data log, KR is reported and increasing without any increase in reported KC. That had me confused. So for tuning SA, I now refer to "KR increase" between frames to detect where knock is occurring. Also, to add to the confusion, Knock Recovery %/sec is not exact. If 100% is entered, you will not get full recovery within a sec. It takes up to double that time. That's based on data log observations. Not sure why but be aware.
Old Oct 25, 2022 | 03:32 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Took me a while to digest this, so consider this:
1)
Where are you seeing "Knock Recovery %/sec"? Can't find this in any XDF. I believe you're referring to the Table at 0x213 "Knock Recovery Rate .vs. RPM" which has a Column Title of "% Retard Removed". See 2) below.
2)
Analyzing the details of the above table, it was discovered the XDF information is incorrect. Below are the particulars one should change until an updated XDF is released. Note that none of the changes below affect the underlying values in the Calibration:
Changes to make to XDF Table at 0x213
- Title to: Knock Retard Reduction Factor .vs. RPM
- Conversion: The value extracted represents the INITIAL percentage reduction of KR Degrees.
---- To: (X / 256) * 100
- Decimal Places: From 1 to 2
- Column Description to: % Retard Reduction
- Description to:
The values in this Table represent the INITIAL Knock Retard Degrees percentage reduction at X RPM. For example, at 3200 RPM, 0x5E (94d) is returned. As a percentage, that’s a 36.7% (94/256) reduction in Retard Degrees in the INITIAL 200ms. Why in 200ms? It’s because this table is only accessed every 200ms. Until KR Degrees are reduced to 0, a factor from this table will be applied to the remaining KR degrees. Mathematically, this means that the percentage reduction after 200ms will not be exactly 36.7%. It could be higher or lower if RPM changes, or if RPM remains the same, the same factor will be applied to continually declining KR Degrees, which changes the percentage reduction.
Old Oct 26, 2022 | 08:06 AM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
1)
2)
- Description to:
Thanks for the info!!!!
Yes it's table 0x213 and my XDF was not up to date for the $8D. So now it is!
I was refereeing to the $6E. So the table is 0x1C7. The XDF I had downloaded for $6E was modified and adapted for my use, so I might have copied some info from the $8D XDF, I don't remember. Nonetheless, it's now corrected. But here what the $6E hack shows:
; KNOCK PCT. RECOVERY RATE vs RPM
; Table values attack rate in PCT.
; RECOVERY/SEC * 256/500
ORG $01C7 ; PCT RPM
LC1C7 FCB 20 ; 39.0 400
LC1C8 FCB 20 ; 39.0 1200
LC1C9 FCB 26 ; 50.8 2000
LC1CA FCB 31 ; 60.5 3200
LC1CB FCB 31 ; 60.5 4800
The conversion appears to be different. It shows "RECOVERY/SEC". Could it be wrong?
Old Oct 26, 2022 | 08:43 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Think I’ll check my .xdf for the LT5 regarding this. However, I have not seen a case in my logs that would show KR when an increase in KC has not occurred.
Old Oct 26, 2022 | 03:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by Dominic Sorresso
Think I’ll check my .xdd for the LT5 regarding this. However, I have not seen a case in my logs that would show KR when an increase in KC has not occurred.
The LT5 ALDL stream reports the whole PA3 counter. Both MSB and LSB.
Whereas the earlier code such as $42, $61, $32, $6E, $8D, $88, and so on only report the MSB.
RBob.
Old Oct 26, 2022 | 04:28 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Thx RBob. Good to hear from u. 👍
Old Oct 27, 2022 | 01:29 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
ORG $01C7 ; PCT RPM
Yes, unless I'm looking at this wrong, it's wrong as was the initial $8d AUJP hack. A bit in the weeds here, but necessary. The $6e usage of the table is identical to $8d. The $6e code below shows, as does $8d, that the table is accessed in Subroutine A (SR-A). While not shown, this is one of 16 such subroutines, each of which are accessed every 100ms. L0000 is the major loop counter which is incremented every 6.25ms. The table is only accessed and knock retard degrees (variable L00A9) reduced by the table's factor when bit 4 of the counter is set. This bit is set every other 100ms, so it would be set every other execution of SR-A, or every 200ms. Review of an 8 bit binary table will verify this. This means the table is accessed and knock retard degrees reduced every 200ms.
Given retard is reduced every 200ms using the table's factor based on RPM at the time, the reduction does not occur every second. A long title for this table might be: Knock Retard INITIAL Percentage Reduction at RPM X every 200ms.
Sure hope I'm not looking at this incorrectly.
Elky
;* MAJOR LOOP SUBROUTINE
;* SEG A, Lk UP Man Air temp Var's
EC2D: LDAB L0000 ; MJR LOOP CNTR
EC2F: BITB #$10
EC31: BNE LEC4E ; BR IF b4
; ... else
; LK UP KNOCK % Recovery rate vs RPM
EC33: LDAA L0058 ; RPM/25
EC35: LSRA ; DIV BY 2
EC36: LSRA
EC37: LDX #$C1C7 ; KNOCK PCT. RECOVERY RATE Tbl (Only place accessed)
EC3A: JSR LF3FF ; 2d Lk Up, (No Offset)
; CALC KNOCK RETARD AS PROD OF
; RATE AND KNOCK RETARD WITH MIN
; VAL HELD TO ONE
EC3D: LDAB L00A9 ; Retard for knock
EC3F: MUL ; RETARD * LK UP RESULT
EC40: ADCA #0 ; ROUND
EC42: NEGA
EC43: BNE LEC47 ; BR IF NZ
; .. else
EC45: LDAA #255 ; USE MAX VAL
EC47: LEC47 ADDA L00A9 ; Retard for knock
EC49: BCS LEC4C ;
; ... else
EC4B: CLRA ; CLR RETARD VALUE
EC4C: LEC4C STAA L00A9 ; Retard for knock
Old Oct 27, 2022 | 02:20 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
T
Just curious as to why the conversion in the $6E is X / 256 * 500 ? Or is it a mistake?
Old Oct 27, 2022 | 10:14 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
All I can say is that the code hacks and XDF files were created by humans. Humans are either correct or make mistakes. All one can do is logically go through the code and determine what actually happens. For me, measuring the reduction in retard degrees in deg/sec is improper because they are reduced by the factor in the table every 200ms. If you want degrees per second, multiply the result by 5 (= reduction in 1000ms).
If the formula in the $6e code can be supported mathematically, then it's correct. if not, it's not. I know the XDF conversion "X / 256) * 100" is correct because I've simulated the SR-A code, and that's the percentage applied to reduce knock retard degrees.
Old Oct 27, 2022 | 10:38 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
I got it now!!!! Thanks again. The more you speak the more we learn.
LoudmouthSS
May 1, 2009 07:42 PM
keeslinger31
Apr 17, 2009 08:37 AM
Cdeez
22
Dec 28, 2008 02:11 PM
jeepguy553
Mar 19, 2004 03:00 PM
