O2 Sensor Alternative Brand
Old Sep 21, 2022 | 06:40 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
I have had good results using AC Delco O2 sensors on my LT5. On a recent search using Rock Auto, they don’t seem to carry AC sensors. I have used Bosch sensors but have been disappointed using them. Any other brands that you would use besides ACs?
Delphi, NTK, Denso?
Old Sep 21, 2022 | 07:22 PM
ULTM8Z's Avatar
Re: O2 Sensor Alternative Brand
Which delco sensor are you attempting to buy?
Old Sep 21, 2022 | 08:10 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
ULT,
Its AC Delco 25176708. I see Summit has 4 of them.
Old Sep 21, 2022 | 08:24 PM
ULTM8Z's Avatar
I've been running the AFS-74 which is a 3 delco wire heated O2
Old Sep 21, 2022 | 08:50 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Just bought 2 AC Delco 213-632 on ebay.
Old Sep 22, 2022 | 01:41 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Probably Bosch or perhaps NTK as AC Delco really just reboxes other manufacturers now.
Old Sep 22, 2022 | 07:55 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
I had used Bosch some years ago. Found that they had a tendency to produce inconsistent readings both in my 84 Xfire and my LT5. I would see strings of 0v readings in my datalogs while cruising. The ACs have never done that altho it seems as if I do need to swap them out on a regular basis. Maybe I should try Denso?
Old Oct 27, 2022 | 03:54 PM
dfarr67's Avatar
For some reason I always reach for NGK/NTK plugs and O2s.
Old Oct 27, 2022 | 05:30 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Currently use NGK plugs. Have used Bosch O2s but found them to be unreliable over time. ACs much more consistent.
Old Oct 28, 2022 | 07:50 AM
dfarr67's Avatar
Never used Bosch except for WB- just economical compared to NTK and Denso.
DoubleV
Mar 31, 2010 04:23 AM
The_Phoenix
Aug 31, 2009 12:05 AM
Dominic Sorresso
Jan 3, 2005 09:18 AM
Gary Anderson
Jun 25, 2002 01:26 PM
