Disabling or limiting knock sensor in '746 TBI ecm
Old Apr 30, 2009 | 04:13 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
For now on the dyno i just unplugged the thing since its pulling timing because of what i believe is just exhaust leak noise. The car did not set the SES light and seems to not be retarding timing at all. However i obviously dont want to run it that way. I see the Knock retard v.s. RPM (in pe) and v.s load as well. However i dont understand the values.
Old Apr 30, 2009 | 08:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Disabling or limiting knock sensor in '746 TBI ecm
You can reduce the amount of knock retard via the two Max Retard tables.
Can also turn off code43 and zero out the two max retard tables along with the code 43 active retard value.
RBob.
Old Apr 30, 2009 | 09:51 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
What's the point of tuning the motor by disabling the knock sensor and then say you don't want to run it that way. The knock is indicating that an issue exists.
Old May 1, 2009 | 07:49 AM
Car: 1991 Z28
Engine: SBC
RBob.
Rbob i dont understand the values in that table i am seeing. Its in %/msec correct? The way i was looking at it was that @ 2000rpm it is leaving in 85% of whatever it is commanding from the SA table and taking out 15%. However i guess this is not the case b/c obviously if i zero this out its going to take away 100% of spark advance. Can you explain this?
So i would zero out:
Knock Retard v.s. load
Uncheck the code 43 flag
and..
what do you mean Code 43 active retard value?
Old May 1, 2009 | 07:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With %/msec values they should be attack tables. The tables I mentioned at the max retard values. Which are SA * (45/256).
When code 43 is active the ECM pulls timing. Zero that value.
RBob.
Chuck84TA
Jul 15, 2016 09:05 PM
stalkier
Dec 6, 2015 11:25 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
