Anyone know of a $DA3 hack (like the ANHT hack)?
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: Anyone know of a $DA3 hack (like the ANHT hack)?
If my brother had any desire to have stuff done to his I'd have build some things out for it. But I'm curious since it seems to be one of the most ignored years of all.
Car: check
Engine: check
Transmission: check
The issue with the LT1 ECM code is multi-fold. It started as OBD-1 and no trans control. Then another PCM with trans control, then a little later a PCM with OBD-2 and trans along with some body control. Nothing was the same year-to-year. Multiple code bases, multiple hardware bases, multiple ALDL data steams.
RBob.
RBob.
I found a reference to it just now...
https://forum.tunerpro.net/viewtopic.php?t=378
Mangus makes reference to it, but it looks like the Moates site is down... is there any way to get hold of this file?
Each mask has different definable and editable items. DA3 is not 8D, therefore these items are different between the two.
With that said, there is likely a bunch of stuff missing from the DA3 XDF. I did not create it, nor do I own a DA3 vehicle, so I can't speak to it's completeness. The best thing to do is use the DA3 hack and add the missing items. The hack is here:
http://www.moates.net/files/5)%20Source%20Code%20and%20Hacks/DA3.zip
M
M
Engine: LB9
Axle/Gears: 3.08
http://www.gearhead-efi.com/Fuel-Inj...mation-DA2-DA3
TDW777
Mar 10, 2005 10:48 PM
Project
Jan 2, 2005 12:28 AM
