27SF512 Bin Stacking
Old Mar 22, 2023 | 04:38 PM
JeepYJv8's Avatar
Car: 1992 Jeep Wrangler + a few more car
Engine: Gm 5.7 T.B.I with 1227747 ECM
Transmission: 700r4 DIY built
Axle/Gears: Ford 8.8/D30- 4:10 and lockers
Hello all, it's been 10 years or more since I messed with my jeep tune with 1227747. Looks like I missed alot. Rip grumpy. What happened to moates? I'm getting back into it some and can't remember how to properly stack bins. I just want to make sure i stack them correctly. I made up a new cable since mine was all rusty and now got it connected to tuner pro and aldl. Now I would like to stack up the bins. I use the moates flash and burn 2. And the moates switch remote that let's me switch between 16 between tunes. My bins are 4k in size. The 27sf512 is 512kb. I set the bin size In tuner pro to 4kb, block size is 32kb, and chip size is 512kb? Is that rite. It doesn't sound rite when I read the data sheet on 27sf512 chip.
As always thanks everyone. Any info you can provide is much appreciated. Want to get this jeep back out in the woods. Been doing alot of work to it lately finially built a garage. Unfortunately need to rebuild the 700r4 yet. I think this will be 3rd time now this time (lost 3rd gear).
Old Mar 22, 2023 | 07:46 PM
JeepYJv8's Avatar
Re: 27SF512 Bin Stacking
Never mind. I remember. Can't figure out how to delete that post now.
Old May 2, 2023 | 08:02 PM
JeepYJv8's Avatar
OK, thats good. if you're sure is a sensor and not a switch. I would perform the troubleshooting steps that sofa listed above. I was Kind of hoping it was a simple fix based on swap + other info.
If you remove wire from sensor the guage goes down. Ground it out to battery at the sensor and the guage pegs?
hotrodta57
Nov 27, 2008 08:45 AM
indirocz28
Mar 5, 2006 05:17 PM
rad8tion
Aug 17, 2004 11:14 PM
Dr G
Apr 7, 2004 02:33 AM
nhromyak
Apr 3, 2004 11:54 AM
