moates APU1
Old Aug 17, 2004 | 11:38 AM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
moates APU1
I am new to prom burning and have 2 questions that I did search for and can't find awnsers:
1 I am using the moates APU1 (same as aps1 but USB) and have the G2 adapter installed, Using tuner pro rt I copied my origional chip and then burned a copy on a AT29C256 chip, when installed the car starts just fine but my SES light flashes, I never drove it or gave it any gas, it I installed my origional chip the SES light went out, What an I doing wrong?
2 Anyone ever used Winaldl with Craig's hardware, is it possible?
Just asking cus I am used to winaldl for data logging but my laptop doesn't have a serial port.
Any help would be much appreciated
Ryan
Old Aug 17, 2004 | 12:03 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
You need to either double up the binary file or burn the bin to the uper half of the chip. The AT29C256 are double the original size of your original chip 32k vs 16k.
TunerPro has the utility to "stack" your bin. Just make sure you setup the block sizes to correspond to what you are doing.
Here is the configuration for stacking a 16k bin onto a 32k chip(AT29C256)
Old Aug 17, 2004 | 01:07 PM
rad8tion's Avatar
Engine: RAMJET 350
Thanks I'll try that. I think my Bin is a 4K file but the theory should help thanks
ryan
Old Aug 17, 2004 | 03:07 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Make sure your checksum is correct (by opening the bin in TunerPro and re-saving it).
If your bin is 4k, set the chip size to 32k, block size to 32k, and bin size to 4k. Then do the stack. Burn to your 29C256, and you're good to go.
M
Old Aug 17, 2004 | 11:07 PM
rad8tion's Avatar
Engine: RAMJET 350
Thanks guys, got it working, now I just need to learn what I am doing.
so far I have figured out how to make the anlu bin work on my manual car. now to learn to tune.
Thanks again
ryan
Old Aug 17, 2004 | 11:14 PM
Mangus's Avatar
Transmission: T5WC
Sweet.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ZZ42Fast
Aug 30, 2015 02:39 PM
Sena'sIROC
24
Jan 19, 2002 06:14 PM
