Checksum values impact engine running?
Old May 19, 2025 | 05:15 PM
ULTM8Z's Avatar
I'm helping a member who's factory broadcast code is ANJF (an 8D Camaro very similar to AUJP). We have his car baselined pretty good on the ANJF-based bins.
However, I'm attempting to get him on to S_AUJP to enable WB Datalogging.
I've transferred all of the fundamental parameters from his ANJF based calibration over to the S_AUJP... spark, fuel, emissions parameters, and every other parameter I could find, except for the checksum values.
Could the checksum values affect engine operation? What's happening is the idle speed is erratic and bouncing around with the S_AUJP but very steady when he puts the ANJF back in.
When I go through and compare the bins in TP, I'm not seeing any differences that could be causing an erratic idle.
Old May 19, 2025 | 05:28 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: Checksum values impact engine running?
If you're saving the vin in tunerpro it should calculate and save the checksum, no?
Old May 19, 2025 | 05:35 PM
ULTM8Z's Avatar
Not sure what you mean by vin (as in Vehicle ID number)?
I guess what I'm saying is that all of these values are different between the SAUJP vs the ANJF... and can any of these impact engine operation?
Old May 19, 2025 | 05:42 PM
Engine: LB9
Axle/Gears: 3.08
bin, not vin
Engine: LB9
Axle/Gears: 3.08
Just change chip code mask to AA instead of 8D
This puts you in a dev mode, where the checksum is ignored.
Old May 19, 2025 | 05:51 PM
ULTM8Z's Avatar
Got it. I'll give that a try. Thanks!
Street Lethal
Nov 27, 2022 10:10 PM
MikeT 88IROC350
Jul 9, 2022 09:16 AM
HowdyDuty
Feb 2, 2007 12:40 PM
Wingnutt
Apr 26, 2006 08:32 PM
